Re: 77 Dodge 360 CI No Power To Starter
[Re: Andrewh]
#535810
11/24/09 09:03 PM
11/24/09 09:03 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
does a 77 still have a starter relay? Is it dead? neutral safety switch?
Neutral safety switch would be my guess too. You might have bumped it loose when you went underneath.
[Re: Reggie]
#535813
11/24/09 09:56 PM
11/24/09 09:56 PM
RapidRobert
I stole this from Stumpy: hold the key to start and move the gear selector thru all the gears & see if it cranks. No go see if you have fire to the yellow "sol" wire to the starter relay while a helper turns the key to "start". At the starter relay pull the wire off of the "grn" terminal & ground this male terminal & see if it will start with the key.
[Re: RapidRobert]
#535814
11/25/09 10:21 PM
11/25/09 10:21 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Check the yellow wire on the starter relay for power when the key is on START position and check the other small lug for ground when in PARK or Neutral.
