What's the current opinion on Ohio Crankshaft cranks?
#535369
11/24/09 12:16 PM
11/24/09 12:16 PM
BradH
Depending upon when this question has been asked in the past, the opinion of Ohio Crankshaft's Mopar cranks have coverage the range from to . So, what's the latest perspective, or - better yet - recent experience, w/ their cranks?
Re: What's the current opinion on Ohio Crankshaft cranks?
[Re: JohnRR]
#535372
11/24/09 01:32 PM
11/24/09 01:32 PM
BradH
... Are you building a stroker or just getting that ticking bomb swapped out?
Common sense says I should simply plan to replace the OEM crank w/ a better 3.75" piece, since it's only a matter of time before it cracks.
The problem when looking at new cranks is that the INITIAL cost of a 3.75" part isn't any different than a 4.25"... It's only when you start to factor in the "butterfly effect" that the REAL cost of adding those extra cubes starts to become clear.
[Re: BradH]
#535373
11/24/09 01:38 PM
11/24/09 01:38 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I have a Ohio 4.15 forged crank in my 499 Challenger. I have fun it for 2 full seasons running two classes a night and have around 600 passes on it. Will be pulling the motor this winter to check it all out. I am very happy with it and it needed zero extra work. Best e.t. is 6.01@112.25 in the 1/8th at 3300lbs.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: BradH]
#535374
11/24/09 02:35 PM
11/24/09 02:35 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Brad, I have sold a lot of the Ohoi stroker cranks for Mopar BB motors that are mild to wild. No come backs yet I did ask them if they where Chinese imported forging that they(Ohio) finished and sold as "American" and they said absolutely not, all of thier forgings come from Ohoi Forge, 100% made in America the one thing I did find on the first batch I bought was the heat treating, they where a # 25 or 26 Rockwell when I had them tested. My crankshaft grinder thought that was a little soft and had me have them reheat treated I don't know what a good heat treat number is for a forged crank Maybe some one who knows will chime in with thier recomendations
[Re: AndyF]
#535379
11/24/09 07:15 PM
11/24/09 07:15 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
4.15 stroke, over 100 runs, 2432 bob weight, approximately 880 hp,7800 rpm. One very minor crack on dis-assembly, ground it out. Crank purchased back in 2002.
[Re: gregsdart]
#535380
11/24/09 10:12 PM
11/24/09 10:12 PM
Posts: 12,157 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
5 years on an Ohio 499" kit. Lots of miles and lots of passes, no problems. I'll buy my next kit from them.
Master, again and still
[Re: AndyF]
#535381
11/24/09 10:23 PM
11/24/09 10:23 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Call around and see what the professional engine builders are using. I'm always surprised when I make a few phone calls and hear what people have to say.
I'd have to call you pretty experienced, Andy. What say you?
[Re: BobR]
#535383
11/24/09 10:34 PM
11/24/09 10:34 PM
Posts: 31,050 Oregon
AndyF
I don't have any experience with Ohio stuff myself. But I was a little surprised the other day when talking to a serious engine builder who was using Eagle cranks and rods in lots of builds. They said the stuff was working great for them. These are guys who make lots of power, not NAPA rebuilder type motors.
[Re: AndyF]
#535385
11/25/09 12:11 AM
11/25/09 12:11 AM
Posts: 5,875 communist bloc of new jersey
jamesc
i was thinking from what i've heard they're (eagle) probably being used in a lot more engines than people realize and as you mentioned we're not talking the "run of the mill" lower HP applications. i wonder how you could ever identify and/or find out exactly what forgings are coming from where as far as the imports and who's using them for cores. it might also be worth noting that as things develop overseas there is the potential that the quality of these pieces will improve. it seems like any other situation they have their differences in quality, ranging from "you really don't want this one" to "this will survive some noteworthy HP"
[Re: jamesc]
#535386
11/25/09 12:19 AM
11/25/09 12:19 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Don't you think the ohio crank, cat, eagle, 440 source, scat and other cheeper stroker kits basically are from the same forging place?
[Re: jamesc]
#535388
11/25/09 02:24 AM
11/25/09 02:24 AM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
I have not had any issues with the four I have used.
