A body trans mount swap #535332
11/24/09 12:02 PM
11/24/09 12:02 PM
Central Vermont
DUSTERB'D Offline OP
Central Vermont
I am looking to swap the old rubber block style trans mount to the new spool type, I have a 416 smallblock and a 727, can I swap with any newer style spool mount from any A body? thanks
Re: A body trans mount swap [Re: DUSTERB'D] #535333
11/24/09 01:21 PM
11/24/09 01:21 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
You need/can use the crossmember from any A body that has the newer/ spool type mount.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: A body trans mount swap [Re: doctor_mopar] #535334
11/24/09 01:31 PM
11/24/09 01:31 PM
Central Vermont
Central Vermont
Thanks for the reply
