Terminator what size #534794
11/23/09 06:56 PM
11/23/09 06:56 PM
Mo.
supercomp Offline OP
Mo.
Which terminater would you use on a 500ci B1, 1450 or 2100 cfm? I trust your opinions on size more then I doJames Monroe's. He know's chevy's not Mopar's. Thanks
Re: Terminator what size [Re: supercomp] #534795
11/23/09 07:15 PM
11/23/09 07:15 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
2100cfm for sure
1450's for duals or for smallblock
Re: Terminator what size [Re: MegaDart] #534796
11/23/09 08:26 PM
11/23/09 08:26 PM
Mo.
Mo.
Thanks, and congrats on your success.
Re: Terminator what size [Re: supercomp] #534797
11/23/09 09:12 PM
11/23/09 09:12 PM
NC
440Jim Offline
440Jim  Offline
NC
This is a good question.
I know you see the general statements on Killer Ron's web site:
The 1475 CFM (2-1/8" Butterfly) TERMINATOR SYSTEM is utilized on engines ranging from 355 cubic inches up to 502.
The 2100 CFM (2-1/2" Butterfly) TERMINATOR SYSTEM has became very prevalent due to the increasing cubic inch and higher horsepower engines being utilized. This system has a wide range of uses from healthy small blocks to 632" Big Chief and Big Duke Engines.
My opinion:
The 2100 CFM will work the same, no down side. The 1475 will work the same, but if you try to go much over 950+ hp it might limit things.
FWIW, my mild Indy 440-1, 511 CID has a 1800 CFM Flying Toilet and works just fine, footbrake and all. I don't need all that airflow, but it doesn't hurt on an injection system for drag racing.
Either way, I think they will set you up with a 0-1/2 pump. Right now Ron's is cutting the price by supplying a gold vane pump (like I have) instead of the more expensive gear pump. But I think the couple hundred more for the gear pump will be a better value over several years (durability). Ask them about this, I have no complaints about my gold vane pump.
This site has a bunch of injection users. Check there. This post isn't exactly your question, but is related. DRR forum
Re: Terminator what size [Re: supercomp] #534798
11/23/09 09:13 PM
11/23/09 09:13 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
FYI, I run a 512 B1, the “bird” flows 4800 CFM. So I don’t think you can go to big. The only “problem” is the engine doesn’t have a part throttle. Only go, and idle.
Joe
Without Data, you’re just another guy with an opinion.
Re: Terminator what size [Re: sr4440] #534799
11/23/09 09:34 PM
11/23/09 09:34 PM
gregsdart Offline
gregsdart  Offline
Joe
2100 unit here. The part about no part throttle is somewhat true. But mine works fine, 528 cubes.
Re: Terminator what size [Re: gregsdart] #534800
11/24/09 10:41 AM
11/24/09 10:41 AM
Mo.
Mo.
Thinks everyone for your replies. I hope I can make it work. Going on a Dragster.
Re: Terminator what size [Re: supercomp] #534801
11/24/09 12:05 PM
11/24/09 12:05 PM
NC
440Jim Offline
440Jim  Offline
NC
So what setup are you going with?
Terminator size
Pump type and size
Nozzle jets
Engine CID and est power?
Re: Terminator what size [Re: 440Jim] #534802
11/24/09 01:08 PM
11/24/09 01:08 PM
Mo.
Mo.
It made 845 on dyno on gas. Have changed cam sense then and picked up .03.
Going to change cam again. Now have a 311/314 @.020 280/283 @.050 .454
lobe with 1.7 and 1.65 jesel rockers. Going to have LSM cut one with 314/322 281/289 .470/. 465 lobe 200/203 at 200 with 4/7 2/3 swap. My idea. Going with a 2100 cfm terminator. If anyone thinks
I'm about to screw up then please speak up. Any opinions are appreciated. I'll let james pick the
pump etc.
Re: Terminator what size [Re: supercomp] #534803
11/24/09 03:15 PM
11/24/09 03:15 PM
NC
440Jim Offline
440Jim  Offline
NC
pump etc.
Good idea. But just for fun I am guessing 0-1/2 black gear pump with 36 nozzle jets and around .086" pill.
Re: Terminator what size [Re: 440Jim] #534804
11/24/09 03:33 PM
11/24/09 03:33 PM
Mo.
Mo.
Think it will pick it up any? Guess we'll see.
Re: Terminator what size [Re: supercomp] #534805
11/24/09 03:52 PM
11/24/09 03:52 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I am gonna guess a 38-40 nozzle, 0-1/2pump and 80 pill. Them BBM's like their fuel!! I'll also guess you pick up .1 [possibly more] once properly tuned.
Re: Terminator what size [Re: MegaDart] #534806
11/24/09 07:50 PM
11/24/09 07:50 PM
ky
68roadrunner Offline
ky
if you change the cam and fuel system both you won't know which one helped the most, or at all.
what size engine and et now?
Re: Terminator what size [Re: 68roadrunner] #534807
11/24/09 08:05 PM
11/24/09 08:05 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run 2 Terminators on my engine in my dragster. It now has # 39 nozzels with a #80 pill. James had them set up with # 38 nozzels and # 86 pill. It would heat up like on gas. I was going to go up to a #40 or #41 nozzel but he said to only go up to the 39 & go down to the 80 pill.Seems to be close now.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Terminator what size [Re: 68roadrunner] #534808
11/24/09 08:36 PM
11/24/09 08:36 PM
Mo.
Mo.
Well we are freshening it up anyway being it has over 500 passes on it. The last time out it went 7.89 at 171. It's a 500ci stock 400 block. While it's apart I'm just going to change both. Not smart I know but I've never been accused of
being smart. Anyone have any opinions on a cam. I was thinking of using Total Seal gapless top, napier second and low tension oil. What do you think? I'm all ears. It has speed pro plasma moly with low tension oil now. 1/16 x 1/16 x 3/16
Re: Terminator what size [Re: supercomp] #534809
11/26/09 01:22 PM
11/26/09 01:22 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have the Cams Motion roller from Indy R2826-2862-11 Specs .799/752 .283/292 this is with Jesel 1.7 rockers. This cam works great & I'm running terminators on alcohol also.
If anyone knows of a better cam. I would like to know while I have my engine down.
Re: Terminator what size [Re: MRMOPAR622] #534810
11/26/09 04:56 PM
11/26/09 04:56 PM
Mo.
Mo.
What size motor? I may give it some thought. Thanks
Re: Terminator what size [Re: supercomp] #534811
11/26/09 05:58 PM
11/26/09 05:58 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
A 528 cu in Bore 4.50 rods 6.570 crank 4.15
Aluminum block with 572-13 heads.They told me at Indy this was the best cam for it.They dynoed it from Indy 938 hp @ 7400 RPM with 1 1095 King Demon 93 Sq. jetted. They said it would make maybe a little more hp @ 7600 rpm if I thought I needed it. At 7400 it is still pulling hard.I was also told Indy dyno hp figures where a lots higher than everyone else's LOL. But it does run good in my dragster.But I'm a Drag-Racer and still want more. Just got my Advanced Profiling Steel Rings yesterday.Maxseal gapless top ring napier style 2nd ring. A member on the Board here
recommended them.The rep @ Total Seal said they were thier best.
Think of having a coating put on the pistons.Some say it will help others say it won't.
Re: Terminator what size [Re: MRMOPAR622] #534812
11/26/09 06:35 PM
11/26/09 06:35 PM
Mo.
Mo.
Our piston tops, skirts, in and ex valves, ex ports and combustion chambers are all coated.
Re: Terminator what size [Re: supercomp] #534813
11/26/09 08:23 PM
11/26/09 08:23 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Who coated everything?
