Re: Anybody use the Jegs NYLON fuel hose???
[Re: Hunted Duck]
#534423
11/23/09 04:08 PM
11/23/09 04:08 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I used the Russell ProClassic nylon hose recently when I re-plumbed gearjammer dart's car. As stated above it is very lightweight and goes together super easy. I did notice that it wanted to kink if you tried to make too tight of a radius with it. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#534425
11/23/09 05:59 PM
11/23/09 05:59 PM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
Mike Gray
Yeah I was looking at that. That looks to be my only concern. I am going to take my #8 stainless braided out tonight and see what kind of bend I can get out of it. Hope I can get it to 90 degrees without it wanting to kink. If not I guess I will buy number 10 stainless. Thanks for the replys guys.
[Re: MegaDart]
#534426
11/23/09 10:40 PM
11/23/09 10:40 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Yep, I re-plumbed both my cars using it and Russell Endura fittings. It is great hose and yes it is light. Incredibly easy to assemble also, no more stainless steel pricking the fingers either! Pretty sure it is Earls product without the namebrand.
So it is Alcohol compatable?? Don
[Re: Hunted Duck]
#534429
11/23/09 11:02 PM
11/23/09 11:02 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
B1, which magnafuel regulator you got? I've been trying to figure out where i'm going to run mine.
Its a 4 port, I currently have 2 ports plugged. I think its part # H5353, and I have it by my motor plate. Not mounted to anything, I think it was Pat Munsi that told me vibrations cause air pockets, best not mount.
