Anybody use the Jegs NYLON fuel hose??? #534420
11/23/09 10:48 AM
11/23/09 10:48 AM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Was wondering if anyone has used the Jeg's pro flo 350 nylon hose or any nylon hose for that matter. Was wondering how well it held up. It is light. Thanks
Re: Anybody use the Jegs NYLON fuel hose??? [Re: Hunted Duck] #534421
11/23/09 11:21 AM
11/23/09 11:21 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Yep, I re-plumbed both my cars using it and Russell Endura fittings. It is great hose and yes it is light. Incredibly easy to assemble also, no more stainless steel pricking the fingers either!
Pretty sure it is Earls product without the namebrand.
Re: Anybody use the Jegs NYLON fuel hose??? [Re: MegaDart] #534422
11/23/09 11:24 AM
11/23/09 11:24 AM
Newark, OH
Newark, OH
Thanks MegaDart. I bought 20 foot of #10 and couldn't believe how light it was. I just bought the Jegs fitting's also but I'm sure someone else is making them also. Only thing I was alittle concered was how it would hold up curving it around things, but might be better cause it will give alittle. Thanks again,
Re: Anybody use the Jegs NYLON fuel hose??? [Re: Hunted Duck] #534423
11/23/09 04:08 PM
11/23/09 04:08 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
I used the Russell ProClassic nylon hose recently when I re-plumbed gearjammer dart's car. As stated above it is very lightweight and goes together super easy. I did notice that it wanted to kink if you tried to make too tight of a radius with it.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Anybody use the Jegs NYLON fuel hose??? [Re: Hunted Duck] #534424
11/23/09 05:14 PM
11/23/09 05:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
Pretty affordable too, I think thats what I'll go with when I replumb my car.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anybody use the Jegs NYLON fuel hose??? [Re: Plumb Wired] #534425
11/23/09 05:59 PM
11/23/09 05:59 PM
Newark, OH
Newark, OH
Mike Gray
Yeah I was looking at that. That looks to be my only concern. I am going to take my #8 stainless braided out tonight and see what kind of bend I can get out of it. Hope I can get it to 90 degrees without it wanting to kink. If not I guess I will buy number 10 stainless. Thanks for the replys guys.
Re: Anybody use the Jegs NYLON fuel hose??? [Re: MegaDart] #534426
11/23/09 10:40 PM
11/23/09 10:40 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
So it is Alcohol compatable?? Don
Re: Anybody use the Jegs NYLON fuel hose??? [Re: MegaDart] #534427
11/23/09 10:46 PM
11/23/09 10:46 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
X2, my car has it except for trans cooler
Re: Anybody use the Jegs NYLON fuel hose??? [Re: B1KILLER] #534428
11/23/09 10:53 PM
11/23/09 10:53 PM
Newark, OH
Newark, OH
B1, which magnafuel regulator you got? I've been trying to figure out where i'm going to run mine.
Re: Anybody use the Jegs NYLON fuel hose??? [Re: Hunted Duck] #534429
11/23/09 11:02 PM
11/23/09 11:02 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Its a 4 port, I currently have 2 ports plugged. I think its part # H5353, and I have it by my motor plate. Not mounted to anything, I think it was Pat Munsi that told me vibrations cause air pockets, best not mount.
Re: Anybody use the Jegs NYLON fuel hose??? [Re: B1KILLER] #534430
11/23/09 11:37 PM
11/23/09 11:37 PM
Newark, OH
Newark, OH
Wow, I've never heard that you shouldn't mount a regulator. That is very interesting. I guess it wouldn't hurt a thing not to. Thanks for the tip. You running 10 line up from the pump and 6 to the carb?
