Re: NHRA rules about side glass
[Re: The Shocker]
#533847
11/22/09 11:06 PM
11/22/09 11:06 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
Call the track you run on first and ask them I haven't seen any cars at the track with colored windows(other than factory tints) in years
[Re: The Shocker]
#533848
11/22/09 11:08 PM
11/22/09 11:08 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Anyone know the NHRA's regulations regarding the use of Plexiglass in the 1/4 windows and doors ?I want to use colored plexi in my Dart for the nostalgia look and ditch the glass and regulators .Im also trying to get back sum of the weight from the rollbar upgrade at the same time.I dont have a rulebook handy ,so i thought one of you guys might know ,thanks...
Plexiglas, Lexan or any shatterproof material no less than 1/8" in thickness.
Tint or Colored needs to be DOT compliant...I think Limo Tint is out, but you should be good to go....
Rickster
[Re: slantzilla]
#533850
11/22/09 11:12 PM
11/22/09 11:12 PM
rickstershemi
I believe by the rulebook that color/tinting other than factory tint is illegal.
It is legal as long as it meets the states requirements.....perctentage of tint.
this is out of the NHRA rule book.
Rickster
[Re: B1KILLER]
#533853
11/23/09 12:22 AM
11/23/09 12:22 AM
Posts: 34,934 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Down here, no one will give you a 2nd look
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: The Shocker]
#533855
11/23/09 02:42 AM
11/23/09 02:42 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
There is a guy with a tri 5 at our track with yellow tint, and another with a 64 Chevy 2 with red tint, and both race with it....
Shouldnt be an issue
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
