06 Daytona slow to up-shift #533629
11/22/09 05:12 PM
11/22/09 05:12 PM
San Jose, California
DennisH Offline OP
Vacation
DennisH  Offline OP
Vacation
Stays in low/first gear longer than normal.
22,000 miles. Wifes driver. No-check German junk 5-speed automatic transmission. Where to start? How about a transmission service like BG? Thanks Moparts.
Re: 06 Daytona slow to up-shift [Re: DennisH ] #533630
11/23/09 06:19 PM
11/23/09 06:19 PM
DennisH Offline OP
Vacation
DennisH  Offline OP
Vacation
Other sources are split between electronic "re-flash, cooler weather, or fluid change. ?
Re: 06 Daytona slow to up-shift [Re: DennisH ] #533631
11/23/09 06:58 PM
11/23/09 06:58 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Actually, those are excellent units in the chargers, so don't discount the transmission as junk. Our 06 Charger had a similar problem a mechanic checked out the code and something came up about a speed sensor. Anyway, it was fixed for a minimal cost but you are going to have to check for codes no way around that with these things.
