Fast ratio pitman arm # ?? #533231
11/22/09 08:59 AM
11/22/09 08:59 AM
Ohio
fiddlestix Offline OP
Ohio
I have a pitman arm with fast ratio cast in to it. The part #'s are 2948714 N16147 Can anyone tell me what this was made for? Where can I find info on part #'s? Thanks for the help
Re: Fast ratio pitman arm # ?? [Re: fiddlestix] #533232
11/22/09 09:27 AM
11/22/09 09:27 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
'70 Challenger T/A-Cuda AAR are the only one I've ever seen with Fast Ratio cast into it.Was used with "T/A" cast into case power steering gear.
Re: Fast ratio pitman arm # ?? [Re: 44D6PAKCUDA] #533233
11/22/09 10:30 PM
11/22/09 10:30 PM
cataclysm80 Offline
cataclysm80  Offline
And if I remember correctly, it will only work on those TA marked steering boxes because those boxes used a larger diameter sector shaft than normal, similar to what's in a C body. (well, maybe you could use it on a C body then?)
Aren't the repro fast ratio pitman arms marked "Fast Ratio"? Any chance you've found an old repro piece? I think the repro piece is designed for use with the regular diameter sector shaft, so if that's what you've got, it would be easier to use.
Tav
Re: Fast ratio pitman arm # ?? [Re: cataclysm80] #533234
11/22/09 10:57 PM
11/22/09 10:57 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Tav
I'm pretty sure the arms and boxes are small sector. I don't think any of the repro's have/had part numbers on them.
The T/A boxes only have different internal end stops. That is so if someone cranked over the steering wheel to the end, and just held it there, it wouldn't force itself so much on the lower control arm to lower ball joint stop or have the tire rub against the inner fender. Sorta idiot proofing.
71 340 E-bodies build after a certain date in spring (March/Feb?) automatically got the fast ratio box and steering arm standard.
There are some C-body pitmans that seem to have the same or close geometry as the fast ratio arm, but the spline is large sector. And the spline indexing is wrong. And you not be able to turn much in one direction, but way to much in the other direction. There was someone once selling a C-body unit like that as a fast ratio. I ran into someone about 10 years ago that had one and figured out the indexing issue and promptly took the pitman off his car.
You could file the master keyways off the C-body pitman and run a 73 up power steering box. I've heard about that. Never seen anything first hand.
Re: Fast ratio pitman arm # ?? [Re: autoxcuda] #533235
11/23/09 02:52 PM
11/23/09 02:52 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Re: Fast ratio pitman arm # ?? [Re: cataclysm80] #533236
11/23/09 07:55 PM
11/23/09 07:55 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Tav
The Firm Feel repro has Fast Ratio cast into the arm but not the part number 2948714
N16147
