need help with doug nash 5 speed ! #532453
11/21/09 09:50 AM
11/21/09 09:50 AM
Georgia
moparjimbo60 Offline OP
Georgia
just picked up a doug nash racing 5 speed at a swap meet with the shifter for 300.00 problem is i am not very familiar withmanual trannys and this one has a couple gears with teeth missing. hope i can still buys gears for it or its a boat anchor. sorry i cant supply much more info, it does have an 18 spline input shaft. any info on this would be awesome , would love to put this in my smallblock demon racecar. thanks jim
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532454
11/21/09 10:43 AM
11/21/09 10:43 AM
AndyF Offline
AndyF  Offline
You should be able to buy replacement parts from Richmond. I just mocked up a Doug Nash on the back of a 340 resto block the other day using a new bellhousing from QuickTime.
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532455
11/21/09 10:51 AM
11/21/09 10:51 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Jim , Deal or no deal? thats the question. Sounds good but lets see what you have. Liberty gears in Michigan has the gears, I bought some used ones from the a couple of months ago. Is it a straight cut gear unit? Does it have syncro's or dog rings? One thing about the trans is it uses mopar a-833 bearings, sliders, shift forks and front bearing retainer.Probably the best thing to do is go to e-bay motors , punch in doug nash , there is usually a guy on there that sells a paper manual. Edit! Send me your address and I'll send you a copy of mine. There are so many gear ratios to deal with you'll need info. to talk intelligently about what you need. The good thing about the trans is there easy to take apart and replace gears, and sliders, just need a good pair of big snap ring pliers. The later transmission had a intermediate bearing to stabilize the shaft.what kind of shifter does it have. It should be worth the $300. you paid for the trans. So if you want , send me your address and i'll get that paper work out to you in mondays mail. Steve
Re: need help with doug nash 5 speed ! [Re: rowin4] #532456
11/21/09 12:14 PM
11/21/09 12:14 PM
Georgia
Georgia
p.m. sent
Re: need help with doug nash 5 speed ! [Re: AndyF] #532457
11/21/09 12:15 PM
11/21/09 12:15 PM
Georgia
Georgia
is that an sfi bellhousing ?
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532458
11/21/09 02:08 PM
11/21/09 02:08 PM
AndyF Offline
AndyF  Offline
Yes
Re: need help with doug nash 5 speed ! [Re: AndyF] #532459
11/21/09 02:17 PM
11/21/09 02:17 PM
Chicagoland
chargerron69 Offline
Chicagoland
nice bells i got one on the way for bb to viper t56 cant wait. ditto on liberty's theyll have everything youll need
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: need help with doug nash 5 speed ! [Re: chargerron69] #532460
11/21/09 02:57 PM
11/21/09 02:57 PM
Georgia
Georgia
where did you get the bellhousing? and about what does it cost, what should i look at as far as flywheel, clutch, pressure plate ?
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532461
11/21/09 06:29 PM
11/21/09 06:29 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
Check the length of the input shaft to make sure it will work. A lot of GM guys use the 18 spline input but it is shorter than the chrysler input.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: need help with doug nash 5 speed ! [Re: gearjammerdart] #532462
11/21/09 08:47 PM
11/21/09 08:47 PM
Georgia
Georgia
how long should the mopar shaft be, it appears long looks like most 833 i have sen but i need to measure it. are these pretty reliable trannys, this one has straight cut gears with dog collars, is this a power shift tranny, if so just how do you shift it.
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532463
11/21/09 08:55 PM
11/21/09 08:55 PM
Quickly Slam, bang, and quick as you can You know your good when the rpm doesn't go up more than 300 RPM on each gear change with a Pro shifted trans., the clutchless trans(which yours may be) should not have any RPM increases on the gear changes, just down on RPMs on each gear change
Re: need help with doug nash 5 speed ! [Re: Cab_Burge] #532464
11/21/09 09:30 PM
11/21/09 09:30 PM
Georgia
Georgia
do you let off the gas any at all or just keep it to the wood and shift?
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532465
11/21/09 10:40 PM
11/21/09 10:40 PM
I have never ran a clutchless trans. so I really don't know. What I remember reading is you need something to take the pressure off of the trans like a RPM limiter or let off the throttle a tiny bit Hopefully onevof the current stick shift racers that have and run a clutchless tranny will chime in and give you the straight scoop on what is done and needed to make your new trans work. BTW, make sure you inspect, magnaflux and check for cracks each and every piece in that trans including both cases and tailshaft housing before racing it
Re: need help with doug nash 5 speed ! [Re: Cab_Burge] #532466
11/21/09 11:43 PM
11/21/09 11:43 PM
rowin4 Offline
rowin4  Offline
It's not a clutchless trans. well maybe, but there $8500 bucks!!! You have to push in the clutch to shift it, don't even try to shift without unless you just want to send liberty more money. I don't take my foot off the gas from the green light to the end of the quarter mile. [ 300 rpm's ] why you shifting so slow? On the in put shaft, I had liberty make a 23 spline out of 300m material and used a billet bearing retainer off a 833 so I didn't have to buy a new clutch setup.
Re: need help with doug nash 5 speed ! [Re: rowin4] #532467
11/22/09 08:27 AM
11/22/09 08:27 AM
Georgia
Georgia
well what is the advantage of straight cut gears if you still have to clutch it. are you just relieving pressure enough for the gear change to take place. this is makeing my head hurt
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532468
11/22/09 11:14 AM
11/22/09 11:14 AM
rowin4 Offline
rowin4  Offline
The gears don't move back and forth while shifting, only the slider which slides on a hub that is connected to the main shaft .The slider is shifted on the hub to connect the gear of choice.
Re: need help with doug nash 5 speed ! [Re: rowin4] #532469
11/22/09 11:33 AM
11/22/09 11:33 AM
Roanoke Va
Roanoke Va
IIRC it should measure 7 1/2 from front of trans to end of pilot. I really doubt it is a clutchless tranny. Keep the gas to the floor and bump the clutch while you are pulling the shifter and it will go. I shifted at 7000 with the doug nash and the graft on the computer would spike 300rpm or so on every shift. As far as reliabilty I started having breakage at around 650hp or so. I know of others that run more hp than that but that is where I had trouble. Now the clutchless tranny on the other hand, I leave it on the wood and pull the shifter at the shift point. The clutchless tranny along with better ratios netted a .3 gain in the 1/8th and two mph. Good luck with the DN if I can help with anything let me know. BTW the video in my sig is with the Liberty
Donald
Re: need help with doug nash 5 speed ! [Re: gearjammerdart] #532470
11/22/09 12:04 PM
11/22/09 12:04 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Go to the "tranny Tech" section of www.umtrnorth.com forums.
Everything you ever wanted to know about Nash trannys is right there.
Re: need help with doug nash 5 speed ! [Re: mloboda] #532471
11/22/09 03:39 PM
11/22/09 03:39 PM
Georgia
Georgia
thanks for all the info its great to have people that have been there , done that.
Re: need help with doug nash 5 speed ! [Re: moparjimbo60] #532472
11/22/09 05:55 PM
11/22/09 05:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I highly recommend sending the gears to Liberty's or Long Machine and Gear to have them "face-plated" for the ultimate in a power-shifting transmission
Gus
64 Plymouth Savoy
Dana 60
