removing horn pad #532415
11/21/09 07:29 AM
11/21/09 07:29 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
I have a one of the three prong horn pads on a 69 charger. how does it come off? I have tried pull , push, bang, turn. now what?
Re: removing horn pad [Re: lukendan] #532416
11/21/09 08:37 AM
11/21/09 08:37 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Pry
Re: removing horn pad [Re: CYACOP] #532417
11/21/09 09:13 AM
11/21/09 09:13 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
The answer is: You have to gently pry out the center medallion & then take out the 7/16" bolt to remove the pad.....
