building a road course car .what would be the best??
#532099
11/20/09 10:41 PM
11/20/09 10:41 PM
Posts: 1,407 northeast ohio
hulmule
northeast ohio
My brother keeps trying to talk me into racing with him on a road course. well i have a AAR but hate to put it on the track, cost to much if i wreck it.I do own GTS big block 4 spd.car but hate to race it also .what can i build for a good road course car.like the old Trans Am series. anyone race road courses?? thanks
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: building a road course car .what would be the best??
[Re: 71Dusterdan]
#532104
11/20/09 11:36 PM
11/20/09 11:36 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
A 70-76 Duster Demon would be the easiest dollar wise. They've got a little more room in the rear for wide tires, decent front tire room, The 73-76 V-8's have the best K-member and sway bar setup.
No one ran a Duster/Demon/Dart Sport in Trans Am though. A-bodies that I know that ran in Trans Am: 66 Dart, 67 and 68 Dart, 68 Barracuda, 66 Barracuda. I believe there are some 65 Darts and Barracudas that have run SCCA A-Sedan.
You could run your AAR with bolt on stuff. Tom's stuff is all bolt on I think. Same ideas transer to on an A-body. But I wouldn't run the 383 Dart GTS just because the front's so heavy.
The question is what you are looking to do with it. Occassional track day, SCCA classed autocross, heavy track days, VARA vintage Trans Am legal, NASA vintage iron class ?...
Do you want to buy a kit or rather piece it together?
[Re: jcc]
#532106
11/21/09 01:57 AM
11/21/09 01:57 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
For the easyst build, a 67 up A body. There is about 10,000 different parts for the A bodys to make then go and corner. That said, a 65 Barracuda can take a 275/60 HR 15 tire inside the wheelwell.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: ThermoQuad]
#532108
11/21/09 10:26 AM
11/21/09 10:26 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Do the A body, you can't build a 60's or 70's car that could be made handle as good for the money. If you took a $1500 4 door dart and about $3500 in parts you could put together one great car for cheap if you do the work yourself. The M body is a lot more trickey to get to work, when I did mine the I could never get the front to work really good, at the time no one made bigger t-bars, the factory ones just did not have enough spring rate. Plus it a lot of work to get rid of all the rubber that holds the rear springs and axle in place. The A boby also has a 300lb weight advantage. Now if you just want to have fun a truck can be a blast and you can use it for halling stuff when your not racing it.
A new iron curtain drawn across the 49th parallel
[Re: PowerWagonDude]
#532110
11/21/09 09:22 PM
11/21/09 09:22 PM
hulmule
northeast ohio
well guys thanks for the great tips. had to post then leave. back again tonight for awhile off on while son does home work. just for fun mostly maybe more if i really like it. maybe my LIL RED with alot of weight in the back so it doesnt come around on me LOL . but i do want to get ready for next season here at nelson ledges.hate to spin out the AAR and crash!! to much money sitting. well lets see what parts i need to do this !!I'll check back in a little bit phil
[Re: hulmule]
#532111
11/21/09 11:14 PM
11/21/09 11:14 PM
autoxcuda
So Cal
well guys thanks for the great tips. had to post then leave. back again tonight for awhile off on while son does home work. just for fun mostly maybe more if i really like it. maybe my LIL RED with alot of weight in the back so it doesnt come around on me LOL . but i do want to get ready for next season here at nelson ledges.hate to spin out the AAR and crash!! to much money sitting. well lets see what parts i need to do this !! I'll check back in a little bit phil
What are you trying to achieve? Do you want to vintage race or just occasional track day. Or a lot of track days?
This list Tom Quad had on his car is really good: https://board.moparts.org/ubbthreads/show...part=4&vc=1
There have been some new items released since then... Like, I think starting with AREngineering Brembo front disk swap would be a better starting point nowadays. That way if you wanted to do to 13" rotors, you'd already have the calipers.
Might want to think about 17" rims nowadays because that is the minimum rim for 13" rotors and there's a little more tire selection.
IHMO, the adjustable hollow rear sway bars that Hotchkis and Hellwig just came out with are an advantage to the Firm Feel style even though the Firm Feel has better routing. They really give you an oppurtunity to adjust the balance of the car.
Other new products to consider: Hotchkis improved geometry upper A-arms, XV engine compartment reinforcing/bracing. Also frame connectors of some sort.
[Re: autoxcuda]
#532112
11/21/09 11:25 PM
11/21/09 11:25 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Im giving it a whack with a 71 bbody xv body mods alterkation But i ran outta money
[Re: autoxcuda]
#532116
11/23/09 02:15 PM
11/23/09 02:15 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
A guy at work used to race his Viper till he crashed it. After repairing it, he was too conservative to be competitive, so he got a dedicated open wheel race car and never looked back. Another guy races in the Hornet class. The cars are 4 cylinders, 70 series tires, and if you win, your car can be claimed for $400. Race junk, spend nothing, and have fun every weekend. Everyone's under the same rules. Those guys actually race. I don't, so that's just my
[Re: topside]
#532118
11/23/09 11:01 PM
11/23/09 11:01 PM
autoxcuda
So Cal
I'd be tempted to build a '63-'66 Valiant, basically an early SCCA A Sedan car, with the best suspension & brakes I could afford, and some modern sticky tires. For really weirding out the status guys, a '60-'62 Valiant or Lancer body with a SB swap would have to be an absolute riot, especially if it had 4 doors. If it weren't for the added weight high & at the rear, a wagon would make heads spin...
That would make a very neat car. I've got a picture of one with that look from Fall Fling. I'll try to find it.
They are the lightest and smallest A-bodies and have a 106" wheelbase for the Plymouths. The 60-62's have weird front suspension.
The car would definitely need some fender flares. But make the gradual so they don't stand out to much; like the 70 race T/A and AAR's had. I'd want to run at least 245 wide tires.
Those cars look pretty good without front bumpers too.
