Setting Dwell #530886
11/19/09 11:57 AM
11/19/09 11:57 AM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
On my 340 factory dual point distributor I just pulled it and replaced the points. I set them at .017 and when I fired it up the dwell was at 32 degrees. It calls for total dwell of 37 to 42 degrees. Do I need a wider gap than .017 or less??
Re: Setting Dwell [Re: Howard] #530887
11/19/09 01:17 PM
11/19/09 01:17 PM
pgh pa
captaindodge Offline
pgh pa
Less
Re: Setting Dwell [Re: captaindodge] #530888
11/19/09 02:51 PM
11/19/09 02:51 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Thanks, I'll try .015 and see what that gives me.
Re: Setting Dwell [Re: Howard] #530889
11/19/09 04:35 PM
11/19/09 04:35 PM
michigan woods
imfixinmopars426 Offline
michigan woods
also,see if you can find a guy with a sun dist machine. they are great to set all curves and dwell off the car.some vo-ed schools might still have one?
