AOD833 granny first gear replacement possible? #530555
11/19/09 03:12 AM
11/19/09 03:12 AM
delivering your oil
nutso suave Offline OP
delivering your oil
i have an AOD833 transmission in my roadrunner and i want to swap out the granny first gear with the regular A833 first gear. is this possible? the 3.09 stump puller is not very useful in a muscle car...but i love the OD 0.73 gear for driving long distances. is it possible? i have read the slant six article several times.
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
it seems like first gear isn't part of the 'flipping' modification:
The Overdrive four speed was a regular A-833 with an overdriven gear set installed in place of the regular third gear. The shift lever on the side cover was flipped over to "fool" the shifter into shifting from second to fourth and then back into third, which was the overdrive gear.
any ideas?
Re: AOD833 granny first gear replacement possible? [Re: nutso suave] #530556
11/19/09 12:00 PM
11/19/09 12:00 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope, won't work. Every gear set is dictated by the cluster gear, plus the main shafts were different between the two (different diameter where the gears ride).
Re: AOD833 granny first gear replacement possible? [Re: Jim_Lusk] #530557
11/19/09 12:50 PM
11/19/09 12:50 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Can't be done. Only other option is to install a passon overdrive gearset. Will bring your strength up to the 18 spline level at least.
Re: AOD833 granny first gear replacement possible? [Re: DaytonaTurbo] #530558
11/19/09 01:18 PM
11/19/09 01:18 PM
delivering your oil
delivering your oil
el crapo! oh well. anyone need any stumps removed?
Re: AOD833 granny first gear replacement possible? [Re: nutso suave] #530559
11/19/09 02:20 PM
11/19/09 02:20 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
any ideas?
take some rear gear out and build an A833 using 3.09/1.92/1.40/1 gearset. Much less spread than the the overdrive A833
Re: AOD833 granny first gear replacement possible? [Re: 446acuda] #530560
11/19/09 03:25 PM
11/19/09 03:25 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
any ideas?
3.23's and a 3.09 first have about the same first overall gear multiplication as a 2.66 1st/3.73, or a 2.47 1st/4.10
but about the same 4th gear multiplication as an A833OD with 4.42 rear gears if such a beast were to exist.
2017 Grand Cherokee Overland
Re: AOD833 granny first gear replacement possible? [Re: patrick] #530561
11/19/09 08:09 PM
11/19/09 08:09 PM
delivering your oil
delivering your oil
hmmmm..this is a very good idea - and cheap! everyone wants 4:10s!
Re: AOD833 granny first gear replacement possible? [Re: nutso suave] #530562
11/25/09 04:44 PM
11/25/09 04:44 PM
Toronto
mshred Offline
mshred  Offline
Toronto
who sells the 3.09 gearset? isnt it an old direct connection close ratio peice?
Re: AOD833 granny first gear replacement possible? [Re: mshred] #530563
11/25/09 05:19 PM
11/25/09 05:19 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
no early A body gear set , and it's not really close ratio
