70 Challenger Correct Fuel Vent line routing Help #530540
11/19/09 01:52 AM
11/19/09 01:52 AM
Mopars4Mark Offline OP
Looking for the correct vent line routing on my Challenger via diagram or photo. Just need to see if I'm correct or incorrect on placement from the fuel filler neck. Anybody have some pictures to post? Looks like mine has been bent while in storage or when we moved to our current location. It would be appreciated. Thanks
Re: 70 Challenger Correct Fuel Vent line routing Help [Re: Mopars4Mark] #530541
11/19/09 01:54 AM
11/19/09 01:54 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
With or without N95?
Re: 70 Challenger Correct Fuel Vent line routing Help [Re: Alaskan_TA] #530542
11/19/09 02:04 AM
11/19/09 02:04 AM
Without. And it's a 6PAK Challenger
Re: 70 Challenger Correct Fuel Vent line routing Help [Re: Mopars4Mark] #530543
11/19/09 02:17 AM
11/19/09 02:17 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 70 Challenger Correct Fuel Vent line routing Help [Re: Alaskan_TA] #530544
11/19/09 02:29 AM
11/19/09 02:29 AM
Hey thanks Barry. It's been about six years since we blew the car apart and wasn't totally sure if the line was correct after that length of time. Sure enough that piece is bent way out of shape. New chore to put it back to correct dimensions. Any idea how the underside will look? I'm sure it's all messed up from top to bottom.
Re: 70 Challenger Correct Fuel Vent line routing Help [Re: Mopars4Mark] #530545
11/19/09 02:40 AM
11/19/09 02:40 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Here you go;
Re: 70 Challenger Correct Fuel Vent line routing Help [Re: Alaskan_TA] #530546
11/25/09 01:56 AM
11/25/09 01:56 AM
Thanks again T/A, Had my daughter help last night after our weekend trip to Georgia for a swapmeet. We ended up having to do allot of straightening on the vent tube to make it fit properly. Used a method, that I've never seen anybody post, as an easy solution. We ended up using 2 paint sticks and a bench vise to pinch the tube and rolling it between the 2 sticks to staighten the long sections of the tube without kinking anywhere. Amazing results after about an hour of work.WELL WORTH THE TIME SPENT. Your pictures steered us in the right direction. Thanks for the help.
