5.9L Magnum Heads and headers (wont seal)
#529875
11/18/09 03:35 PM
11/18/09 03:35 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Anyone know of a header that will seal well up against magnum exhaust ports? The Dynomax headers I had sealed fine up to an LA head (plenty of contact to machined area all the way around ex port) but the magnum exhaust port is raised and the bottom of the header flange opening barely overlaps the lower machined surface of a magnum head (under the exhaust port opening).
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 5.9L Magnum Heads and headers (wont seal)
[Re: Rapid340]
#529877
11/18/09 05:14 PM
11/18/09 05:14 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
I have dynomax headers that were on my LA360 that I reused when I swapped over to 5.9 Magnum engine. They didn't seal the first time out so I tried some new gaskets but used high temp RTV this time around and they seal up just fine now.
[Re: chache876]
#529878
11/18/09 06:00 PM
11/18/09 06:00 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
summit long tube headers (I think they're flowtechs) seal up fine on my mag heads using copper RTV on the gaskets.
[Re: patrick]
#529879
11/18/09 06:51 PM
11/18/09 06:51 PM
Rapid340
oberlin, Ohio
My thinking is if the header flange seals fine on a magnum head, it may cover some of the lower part of the ports on an X or J head.
[Re: Wedgeman]
#529883
11/19/09 11:50 PM
11/19/09 11:50 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
you are not imagining this problem! There is only about 3/16" common area comparing the bottom of the LA port to the bottom of the Magnum port.
you're looking at an LA gasket crushed against a Magnum port.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#529884
11/19/09 11:57 PM
11/19/09 11:57 PM
GO_Fish
Maryland
I made sheet metal adapters, outside dimensions of the LA port, and inside dimensions of the Magnum port. Sandwiched the adapters against the magnum port with LA gaskets between the adapter and the manifold (or header). These adapters along with a Remflex gasket solved my leaks.
Some report a hump on the Mag heads that stops the manifold from sitting flat, I did not see that in my case. The Remflex gaskets are good enough that they may still seal without the adapter plates.
Scott B.
