Motorplate or Mounts? #529802
11/18/09 02:02 PM
11/18/09 02:02 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
I have a 70 Dart that runs 10.30's-10.40's. Transbrake car currently has a 727 might switch back to a 904. 408 smallblock. 1.40 60ft's. Would I be fined on the mounts or should I run the motorplate.
Re: Motorplate or Mounts? [Re: Hunted Duck] #529803
11/18/09 02:43 PM
11/18/09 02:43 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
race only should use a motor plate. The mounts can distort the block.
Re: Motorplate or Mounts? [Re: TS3303] #529804
11/18/09 02:49 PM
11/18/09 02:49 PM
an8sec70cuda Offline
Once you go with a plate, you'll never want to use mounts again. They are much easier to work with, not to mention give you a great place to mount stuff. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Motorplate or Mounts? [Re: Hunted Duck] #529805
11/18/09 03:34 PM
11/18/09 03:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Motor plate with also limiters added to keep the block from moving forwards or rearwards.
Re: Motorplate or Mounts? [Re: Bob_Coomer] #529806
11/18/09 08:37 PM
11/18/09 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
dont let the trans mount be the limiter,
use actual limiters on the engine(dont put the added
stress on the trans)
