Re: comp 948 springs? [Re: gregsdart] #529030
11/19/09 09:57 PM
11/19/09 09:57 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Love my 948's. Ran K1000h's and they would break over winter sometimes. Mine in at 2.10.
The little old lady from Pasadena is back!
Re: comp 948 springs? [Re: Barnstorm] #529031
11/20/09 12:00 AM
11/20/09 12:00 AM
gregsdart Offline OP
Al, took a look at the PAC web sight. Very informative.
Barnstorm, should see you at BIR this next season.
What combo motor heads cam, etc are you running? RPM?
Re: comp 948 springs? [Re: gregsdart] #529032
11/20/09 08:28 AM
11/20/09 08:28 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
G.A. That new 1/2"x.188" pushrod has some mass, you might consider the higher rate spring especially with steel valves. That is a significant increase in weight. With all these changes a larger (stiffer) camshaft diameter would show improvements.
Re: comp 948 springs? [Re: gregsdart] #529033
11/20/09 11:02 AM
11/20/09 11:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pardon my ignorance but what is the largest diameter valve spring you can use? Isn't the 948 a 1.650? I ask becuase if you can squeeze in a larger diameter it opens up more possibilities.
Re: comp 948 springs? [Re: gregsdart] #529034
11/20/09 11:57 AM
11/20/09 11:57 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
My dilemma is not being able to get a correct spring to fit with a 2.050 max installed height, yet still allow .850 net lift.
As much as I like Comp, I'd switch to a PAC spring.
The PAC-1248 will handle a .900 lift easily. Its specs are:
PAC-1248: 350 lbs @ 2.050, 950 lbs @ 1.20
This spring is spec'd to .900 lift
The PAC 1246 is a little less pressure and although this spring is spec'd to .800 lift, I have run them many times with .850 lifts with no problems.
PAC-1246: 250 @ 2.050, 830 @ 1.20
Re: comp 948 springs? [Re: Mopar_Rich] #529035
11/20/09 01:08 PM
11/20/09 01:08 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Pieces like this (among others)makes the thread better...people adding their personal experience data. The post on YB was lengthly back and forth. I summed-up that unless your running specific parts with a spintron, laser and stress instrumentation, confidence in valvetrain dynamics comes from correctly evaluating experience(just like anything else I guess).
Re: comp 948 springs? [Re: Mopar_Rich] #529036
11/20/09 05:46 PM
11/20/09 05:46 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Really, this would exceed coil bind by 0.050 at zero lash and 0.025 at 0.025 lash. Even wiht deflection, I wouldnt run this at .900 lift at the valve.
8.30's @3400 lbs
Re: comp 948 springs? [Re: Mike Swann] #529037
11/20/09 05:57 PM
11/20/09 05:57 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I don't agree. Here's the data from PAC.
It shows an installed height of 2.1, but in this case the installed height would be 2.050. Even at .900 lift that puts the spring at 2.050 - .900 = 1.150, with stated coil bind not occurring until 1.130.
Re: comp 948 springs? [Re: Mopar_Rich] #529038
11/21/09 03:13 PM
11/21/09 03:13 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Well Greg, Whatareyagonna do?
Re: comp 948 springs? [Re: HardcoreB] #529039
11/21/09 04:25 PM
11/21/09 04:25 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
My B1 heads came with PSI-1248 installed at 2.100"
DR1248,Triple,diam1.660",375lbs@2.100",1045lbs@1.200"
coil bind 1.130"
Maybe PSI-1247 would fit at 2.050" installed height ?
DR1247,Triple,1.660",340lbs@2.070",940lbs@1.270"
coil bind 1.130"
Re: comp 948 springs? [Re: Mopar_Rich] #529040
11/21/09 07:26 PM
11/21/09 07:26 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Rich, if you are really going to lift the valve .900, the installed height should be 2.15-2.2. Even then, you would have infinitesimal performance gain and a lot of heartache with anything short of a late 90's or later series PS head, IMO.
8.30's @3400 lbs
Re: comp 948 springs? [Re: Mike Swann] #529041
11/21/09 09:27 PM
11/21/09 09:27 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I totally agree. I was only trying to suggest that there are springs out there that will take the lift, if you have to have it. No one should try to get these lifts with a short installed height when there are ways to get the installed height to the correct values, such as longer valves, offset locks, offset retainers, and head machining.
Re: comp 948 springs? [Re: Mopar_Rich] #529042
11/22/09 11:48 PM
11/22/09 11:48 PM
Thanks guys, I really appreciate the input. My choice is for a cost reason; I put so few runs on the car, the 948 would be my choice if I need them. I will check the 947 springs I have to make sure they are close to spec, and am starting the season with the same rocker ratio I have to keep things simple. I can install them at less than 2.00 and still have room.
If i decide to go for this extra lift, the comp 948 springs can be installed at 2.050 and give me 355 seat pressure, and would allow a NET lift of .860 which is .050 more than my proposed change. As mentioned, a larger cam core might be needed, as I run a stock bearing sized cam, and lose a lot of lift just rolling it over on the stand. So not knowing enough about possible consequences at this point, I will wait to make my move.
Re: comp 948 springs? [Re: gregsdart] #529043
11/23/09 01:53 AM
11/23/09 01:53 AM
Arizona
Chris'sBarracuda Offline
Arizona
Greg..
Here is a really good conversation about almost the same thing.
After reading this some time ago, I decided to go with PAC..1324's
http://www.speedtalk.com/forum/viewtopic...a27acd8c7185cf1
Chris..
Re: comp 948 springs? [Re: Chris'sBarracuda] #529044
11/23/09 11:09 AM
11/23/09 11:09 AM
Hey Chris, coming to AZ in Feb, would like to see your car run. Possible?
Re: comp 948 springs? [Re: gregsdart] #529045
11/23/09 08:36 PM
11/23/09 08:36 PM
Arizona
Arizona
Working on it...
As of right now I'd say yes..
Chris..
