Page 1 of 3 1 2 3
Painting wiper motors #528693
11/17/09 01:31 AM
11/17/09 01:31 AM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
Any tips on painting a 3 speed wiper motor? Mine looks terrible and I would like to give it a coat of paint. I'm also have some miscellaneous parts powder coated soon and would prefer to just have it powder coated as well. Is it easy to pull these things apart and put the back together? Will I need any gaskets, etc...?
Re: Painting wiper motors [Re: chache876] #528694
11/17/09 09:02 AM
11/17/09 09:02 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...the housing can usually be made respectable with a wire wheel.
get 2 or 3 "different" spray bombs of gold and one of silver.
alternately dust the motor housing with all four in no particular pattern so it has large sections of each shade blended and clear coat when finished.(gold and alum. are soft paints)
it won't look like the restored gold irridated ones but will look nice and close to original which was quite dull
splash the wires and back w/red oxide primer....
.al
Re: Painting wiper motors [Re: chache876] #528695
11/17/09 09:35 AM
11/17/09 09:35 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a tip, send it to Jules and never have to deal with it again. Do it right once. 3 speed wiper motors look really bad, and cheap unless they are done correctly.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Painting wiper motors [Re: MOPARMIKE69] #528696
11/17/09 10:31 AM
11/17/09 10:31 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
Jules does outstanding work!
Re: Painting wiper motors [Re: repad] #528697
11/17/09 10:36 AM
11/17/09 10:36 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
X3
He has posted his work here, and the quality shows!
Re: Painting wiper motors [Re: MOPARMIKE69] #528698
11/17/09 01:35 PM
11/17/09 01:35 PM
Southeast Michigan
Mr Belvedere II Offline
Southeast Michigan
Jules is the top choice, but if you are on a budget (like I am), you can do a decent job on your own.
Remove the cover on the transmission.
Clean the entire assembly using a Scotch Brite pad.
Clean the cover for the transmission and the harness with 409 or Simple Green.
Carefully tape the motor portion off as well as the part where the cover was. Paint this with Eastwood Aluminum (or equal). Remove the tape and allow this to dry for 2-3 days.
Using a painters tape, tape off the newly painted portion and spray the body - here is the point of contention - black. Some should be zinc chromate, so the Eastwood system would work, but I like Black. It my car after all.
Clean all of the hardware on a wire wheel (polish the ground strap). and reassemble. Retape the harness and there you go. I think my motor looks decent and it only cost about 20 bucks to do. That gives me more $$ for the budget!
67 Belvedere II 225 Slant Six 383 on the stand The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants. - Thomas Jefferson
Re: Painting wiper motors [Re: repad] #528699
11/17/09 06:07 PM
11/17/09 06:07 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...i thought he was asking how to do it...
Re: Painting wiper motors [Re: MOPARMIKE69] #528700
11/17/09 06:37 PM
11/17/09 06:37 PM
Costa Mesa, CA
Costa Mesa, CA
Thanks I've seen his work and its amazing, however I can't justify spending $300 on a wiper motor.
Re: Painting wiper motors [Re: Mr Belvedere II] #528701
11/17/09 06:40 PM
11/17/09 06:40 PM
Costa Mesa, CA
Costa Mesa, CA
Thanks I might try your approach. What did you do with the wires? It looks like they are soldered on the case...just unsolder then paint, resolder later?
Re: Painting wiper motors [Re: MOPARMIKE69] #528702
11/17/09 08:01 PM
11/17/09 08:01 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
You may want to re-read this response especially the last line. I have never seen what I consider a respectible job on a three speed wiper motor which was painted. Plating is the right way to go. Also the price charged for doing it right (complete restoration) not only includes the finish but the internals are restored, wires and any other worn parts are replaced. That said, you may want to consider removing the barrell and have it plated.
Re: Painting wiper motors [Re: chache876] #528703
11/17/09 08:31 PM
11/17/09 08:31 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Well I was in the same boat as you. My wiper motor looked horrible. One of the past owners spray bombed the motor black in the engine compartment. Here is a pic of it.
Ron
Re: Painting wiper motors [Re: Ronnman] #528704
11/17/09 08:43 PM
11/17/09 08:43 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I took the wiper motor assembly off and cleaned it up real good. Sprayed the transmission part with Eastwood's Aluma Blast, the motor with a gold from the touch-up aisle, the motor end housing with a different aluminum paint. I repainted the epoxy covering the wires with a brushed on red Rustoleum enamel. Came out good for what it is. If you want perfection, go to Jules as mentioned. Here's a pic of the wiper asssembly about 2 years old now.
Ron
Re: Painting wiper motors [Re: Ronnman] #528705
11/17/09 08:47 PM
11/17/09 08:47 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Another pic.
Ron
Re: Painting wiper motors [Re: Ronnman] #528706
11/17/09 10:09 PM
11/17/09 10:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Ronnman...your wiper motor looks very good. Yours is probably the nicest one I've seen that has been "home restored"
For me personally though, I can't justify spending a ton of money on the body/paint and then NOT have Jules do the motor. Anything less won't cut it. I'm shipping mine to him tomorrow.
Re: Painting wiper motors [Re: Ronnman] #528707
11/17/09 10:10 PM
11/17/09 10:10 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
All good responses.
Here is a tease
Re: Painting wiper motors [Re: JulesdaWiperman] #528708
11/17/09 10:21 PM
11/17/09 10:21 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Ronnman, your paint job looks fantastic. I think it is a great option for guys on a budget and I appreciate you showing us your handy work. I also really like the stuff Jules is doing also. Some top notch stuff. I guess I will wait till my car is painted and on it's way to being put back together to decide what my budget can afford and how the rest of the job is going to decide what route I am going. A guy certainly could do a home restore like you did to get by for a while then upgrade to a "Jules motor" when money allows it.
Re: Painting wiper motors [Re: moparmojo] #528709
11/17/09 10:56 PM
11/17/09 10:56 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Also, remember Jules is taking the wiper assembly completely apart, cleaning, servicing, replacing wear items and then replating the components. It's more than an exterior makeover. I had just choose to clean and paint mine because it looked so hideous.
Ron
Re: Painting wiper motors [Re: moparmojo] #528710
11/18/09 10:43 AM
11/18/09 10:43 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You budget minded people are not looking at the whole picture. You must have never had to try to replace the entire wiper system with the dash in place. Save money on stuff you can get to and unbolt in a few minutes. If the car is apart, there is no way I am going to not replace with correctly restored parts the wiper assembly, master cyl. and heater box and dash assembly.
I love my time and efforts and arms and hands and skin too much to do it more than once. And even though everyone in being nice, as soon as you look at the painted wiper motor you know what you are thinking.
If your budget is too tight to restore the wiper motor and never have to touch it again you need a different hobbie. After years and thousands and thousands of dollars to paint your car and you skip the wiper motor???
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Painting wiper motors [Re: MOPARMIKE69] #528711
11/18/09 01:03 PM
11/18/09 01:03 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I understand that people are on a budget. If I couldn't get mine properly done (plated) then I'd chemically clean it or soda blast it and leave it alone rather than paint it.
Another teaser; wiper motor by jules;
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Painting wiper motors [Re: chache876] #528712
11/18/09 04:24 PM
11/18/09 04:24 PM
Southeast Michigan
Southeast Michigan
They are not soldered (from what I remember), just tape them.
Page 1 of 3 1 2 3
