Re: Painting wiper motors
[Re: chache876]
#528695
11/17/09 09:35 AM
11/17/09 09:35 AM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Here is a tip, send it to Jules and never have to deal with it again. Do it right once. 3 speed wiper motors look really bad, and cheap unless they are done correctly.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#528696
11/17/09 10:31 AM
11/17/09 10:31 AM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
Jules does outstanding work!
[Re: MOPARMIKE69]
#528700
11/17/09 06:37 PM
11/17/09 06:37 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Thanks I've seen his work and its amazing, however I can't justify spending $300 on a wiper motor.
[Re: Mr Belvedere II]
#528701
11/17/09 06:40 PM
11/17/09 06:40 PM
chache876
Costa Mesa, CA
Jules is the top choice, but if you are on a budget (like I am), you can do a decent job on your own.
Remove the cover on the transmission.
Clean the entire assembly using a Scotch Brite pad.
Clean the cover for the transmission and the harness with 409 or Simple Green.
Carefully tape the motor portion off as well as the part where the cover was. Paint this with Eastwood Aluminum (or equal). Remove the tape and allow this to dry for 2-3 days.
Using a painters tape, tape off the newly painted portion and spray the body - here is the point of contention - black. Some should be zinc chromate, so the Eastwood system would work, but I like Black. It my car after all.
Clean all of the hardware on a wire wheel (polish the ground strap). and reassemble. Retape the harness and there you go. I think my motor looks decent and it only cost about 20 bucks to do. That gives me more $$ for the budget!
Thanks I might try your approach. What did you do with the wires? It looks like they are soldered on the case...just unsolder then paint, resolder later?
[Re: MOPARMIKE69]
#528702
11/17/09 08:01 PM
11/17/09 08:01 PM
repad
super street
super street
N.E Indiana
You may want to re-read this response especially the last line. I have never seen what I consider a respectible job on a three speed wiper motor which was painted. Plating is the right way to go. Also the price charged for doing it right (complete restoration) not only includes the finish but the internals are restored, wires and any other worn parts are replaced. That said, you may want to consider removing the barrell and have it plated.
[Re: Ronnman]
#528706
11/17/09 10:09 PM
11/17/09 10:09 PM
Posts: 7,363 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Ronnman...your wiper motor looks very good. Yours is probably the nicest one I've seen that has been "home restored" For me personally though, I can't justify spending a ton of money on the body/paint and then NOT have Jules do the motor. Anything less won't cut it. I'm shipping mine to him tomorrow.
[Re: moparmojo]
#528710
11/18/09 10:43 AM
11/18/09 10:43 AM
MOPARMIKE69
Nashville, TN
You budget minded people are not looking at the whole picture. You must have never had to try to replace the entire wiper system with the dash in place. Save money on stuff you can get to and unbolt in a few minutes. If the car is apart, there is no way I am going to not replace with correctly restored parts the wiper assembly, master cyl. and heater box and dash assembly. I love my time and efforts and arms and hands and skin too much to do it more than once. And even though everyone in being nice, as soon as you look at the painted wiper motor you know what you are thinking. If your budget is too tight to restore the wiper motor and never have to touch it again you need a different hobbie. After years and thousands and thousands of dollars to paint your car and you skip the wiper motor???
[Re: MOPARMIKE69]
#528711
11/18/09 01:03 PM
11/18/09 01:03 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I understand that people are on a budget. If I couldn't get mine properly done (plated) then I'd chemically clean it or soda blast it and leave it alone rather than paint it. Another teaser; wiper motor by jules; Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
#528714
11/18/09 05:12 PM
11/18/09 05:12 PM
chache876
Costa Mesa, CA
Not everyone has a spare $300 for a wiper motor!
I agree Jules is the master and when I can afford a car that is both rare and desireable, I will probably pony up the 3 bones, but on a 67 Belvedere with a factory slanty, I just cannot justify the expense.
$300 will rebuild a front end, buy a driveshaft for the 383 conversion, put a 3:55 in the 8 3/4 or put an exhaust under the car.
I agree. Plus a painted wiper motor would that people look at in disgust would still be a lot better than what I have lol
[Re: moparmojo]
#528720
11/19/09 08:04 PM
11/19/09 08:04 PM
chache876
Costa Mesa, CA
Well as long as the part is cleaned and freshly redone (whether to original finishes or not) I am fine with it. I also think it depends on what you are doing with car. Not everyone can afford or pull off a top notch resto. But that is not to say I would ever thumb my nose at another car guy because his car wasn't done exactly like the factory did it. I hope our hobby hasnt gotten that ridiculous.
Yeah I guess I should have specified that I don't have a T/A Challenger or Hemi Cuda, its just a lowly original /6 Demon...IE doesn't have to be factory original looking.
[Re: chache876]
#528731
02/05/10 07:41 PM
02/05/10 07:41 PM
Posts: 114 Sunny FL
p4m
Sunny FL
chache you can use Rustoleum Spray On Airline Stripper, I find mine at Auto Zone for under $10 a can, pretty nasty stuff if you get it on your skin, but it will clean every nook and cranny on that housing. Let it sit about 10 minutes, blast it with water from the hose (that's how I've done it), let it dry and it's ready for paint....if you're going to paint it.
If you don't wanna paint that bad boy and the motor is apart, send it to me and I'll blast that housing and return it to you. I've been there, done that, before I had the equipment to build the way I do now, I had people help me, and now I'm paying it forward....
