Removable Trans Tunnel ????? #528435
11/16/09 08:43 PM
11/16/09 08:43 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
I've been contemplating making my tunnel removable. Is it really as simple as cutting the old one out or does the floor need to be reinforced some how? What would be the best material to use and how would I go about forming it without a palnel roller?
FWIW the car has a stock floor/firewall as well as subframe conectors and a cage.
Is this something I can do in my gagage or would it be better to farm it out to my chassis guy?
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528436
11/16/09 09:17 PM
11/16/09 09:17 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The stock floor pan has plenty of stregth to support a removable transmission tunnel. The torsion bar/transmission crossmember shapes the floor for the tailshaft portion of the tranny. You could easily cut the tunnel and form a peice of .032 alluminum for the tunnel. Drill and dzus fasten the alluminum to the floor. You will need to leave a 2" lip next to the firewall as this will be the most difficult area to seal. You will difineately need some bead rolls of some kind to give the panel some rigidity.
If you are simply trying to obtain a way to better access the bell housing bolts. It would be better to mark and drill the floor and get some plugs for the holes. Electrical box 1" plugs work nice. Just an option.
Leon
Re: Removable Trans Tunnel ????? [Re: Leon441] #528437
11/16/09 09:39 PM
11/16/09 09:39 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
You can look though all these pics and maybe help you
http://s241.photobucket.com/albums/ff92/vernmotor/Dart/
Re: Removable Trans Tunnel ????? [Re: VernMotor] #528438
11/16/09 10:07 PM
11/16/09 10:07 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Ya you can do it yourself. I've seen some of the other things you've built. This should be know problem. I got 3 fasterners on each side holding it together.
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528439
11/16/09 10:29 PM
11/16/09 10:29 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
then the
Re: Removable Trans Tunnel ????? [Re: Hunted Duck] #528440
11/16/09 10:30 PM
11/16/09 10:30 PM
BROOK PARK, OH
BROOK PARK, OH
I acctually have a lot of room to access the bell housing bolts on this car. But I would like a little more room and have easier acces to adjusting the shifter cable and installing the blanket. Not to mention that if I did want to try installing a sheild again it would be needed.
Jeff, I appreciate the vote of confidence. Just not sure I can get it done with out buying more equipment that I can't afford or justify.
Jamie, did you form it by hand or do you have a panel and bead roller at your disposal?
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528441
11/16/09 10:52 PM
11/16/09 10:52 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
All you need is a sawsall and and a pop rivet gun. I formed my sheet steel over a 55 gallon drum.
Re: Removable Trans Tunnel ????? [Re: Hunted Duck] #528442
11/16/09 11:03 PM
11/16/09 11:03 PM
BROOK PARK, OH
BROOK PARK, OH
Don't have one of those either
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528443
11/16/09 11:10 PM
11/16/09 11:10 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Dang Bill...lol. Gotta have something around the garage????
Re: Removable Trans Tunnel ????? [Re: Hunted Duck] #528444
11/16/09 11:37 PM
11/16/09 11:37 PM
BROOK PARK, OH
BROOK PARK, OH
I might be able to use an old steel wheel. I'ld have to find something for the other end.
What about rolling the beads.
And where might I be able to get the material? can't get something that big at the hardware store.
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528445
11/16/09 11:47 PM
11/16/09 11:47 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
I didn't bead roll mine. I would say a machine shop has the sheet steel you need. Just use your knee for the other end
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528446
11/17/09 12:05 AM
11/17/09 12:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I didn't make mine removable as the trans still has to come out the bottom. I did enlarge it to fit the shield and remove trans and components easily. I bent it over a 8" peice of pcv from Home Depot.
Heres the cut.
Doug
Re: Removable Trans Tunnel ????? [Re: dvw] #528447
11/17/09 12:09 AM
11/17/09 12:09 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I slid the piece in the hole. Tack welded the edge and welded it from the top. Then I went to the bottom and trimmed off the excess sticking thru. I welded underneath and metal finished the edge. Heres the finished product. Plenty of room.
Doug
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528448
11/17/09 10:21 PM
11/17/09 10:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Sorry Bill I just seen this..I have a bead roller and Shrinker & Stretcher tools..Do you know what a buck is? I made one for the tunnel shape..I have a welder..Lots of hand air tools..One thing us old men have is lots of tools LOL
Re: Removable Trans Tunnel ????? [Re: VernMotor] #528449
11/17/09 10:25 PM
11/17/09 10:25 PM
BROOK PARK, OH
BROOK PARK, OH
I've got a pretty well equiped shop out back but I don't have anything for doing sheet metal work.
No I don't
Re: Removable Trans Tunnel ????? [Re: WILD BILL] #528450
11/17/09 10:37 PM
11/17/09 10:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
It is a wood mold you make. to fit your metal around to shape.
Re: Removable Trans Tunnel ????? [Re: VernMotor] #528451
11/17/09 10:42 PM
11/17/09 10:42 PM
BROOK PARK, OH
BROOK PARK, OH
Wood?
All I can make out of wood is charcoal and saw dust
Post deleted by Defbob [Re: WILD BILL] #528452
11/17/09 11:04 PM
11/17/09 11:04 PM
Re: Removable Trans Tunnel ????? #528453
11/17/09 11:33 PM
11/17/09 11:33 PM
sg66mopar Offline
sg66mopar  Offline
Looks to me like that scoop on your car is about the right shape. Go for it.
Re: Removable Trans Tunnel ????? [Re: sg66mopar] #528454
11/17/09 11:47 PM
11/17/09 11:47 PM
BROOK PARK, OH
BROOK PARK, OH
Is that how you did yours?
