Page 3 of 4 1 2 3 4
Re: 360 performance [Re: dustergirl340] #527534
01/06/10 11:16 AM
01/06/10 11:16 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
How much does a '72 Satellite weigh anyway? My supposedly 'light' '73 A-body weighs 3,500 pounds with me in it. I can't see a Satellite weighing that much more.
A 340 small block propels my fat Duster just fine.
the motor is a runner out of my 5th ave, which w/o me is 3950 lbs....granted I sold it to him without the eddie RPM air gap and eddie 600, and IIRC he's got a performer and I think either a 600 carter AFB or 600 holley....
with a MP166k converter and 3.55's, it would light up the tires of my boat (255/50R17's) and keep up with a stock LX 300 hemiC AWD from a roll....
just get the dang thing in and running already!
2017 Grand Cherokee Overland
Re: 360 performance [Re: patrick] #527535
01/06/10 11:59 AM
01/06/10 11:59 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
4 dr, 4spd, 323" 3.23 geared, A body has the 340 hp cam .429/.444" and shaved 1.88/1.60" 318 heads, summit headers. Toppped off with a Edelbrock 318 Streetmaster SP low rise intake and 600 holley. Tuned Stock HEI curve very well. The 4dr is fast as a stock 90's 5L mustang 5 speed. First 4 gears anyway.
Mid 14's ain't bad. That's from a 318 4 spd with bolt ons.
14 mpg city/15 highway.
Re: 360 performance [Re: patrick] #527536
01/09/10 05:05 AM
01/09/10 05:05 AM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
lol i just got it all in as off 2 hours ago
Re: 360 performance [Re: erick72] #527537
01/09/10 05:22 AM
01/09/10 05:22 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well drive it and beat the hell out of it. You can always tell yourself you'll do a big block once you blow the 360, which will probably never happen.
Re: 360 performance [Re: DaytonaTurbo] #527538
01/09/10 04:29 PM
01/09/10 04:29 PM
E
erick72 Offline OP
erick72  Offline OP
E
finally got it in!
Re: 360 performance [Re: erick72] #527539
01/09/10 04:31 PM
01/09/10 04:31 PM
E
erick72 Offline OP
erick72  Offline OP
E
another.throwing the holley onn.
Re: 360 performance [Re: erick72] #527540
01/09/10 04:33 PM
01/09/10 04:33 PM
E
erick72 Offline OP
erick72  Offline OP
E
stuffing that bad boy in. do you guys think i can get headers in from under?
Re: 360 performance [Re: erick72] #527541
01/09/10 04:34 PM
01/09/10 04:34 PM
E
erick72 Offline OP
erick72  Offline OP
E
tranny almost under the humppp!
Re: 360 performance [Re: erick72] #527542
01/09/10 04:36 PM
01/09/10 04:36 PM
E
erick72 Offline OP
erick72  Offline OP
E
alll innn
Re: 360 performance [Re: mark7171] #527543
01/09/10 05:13 PM
01/09/10 05:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Only way that a 318 had those heads is if someone put them on or the engine was a 318 4 barrel engine which used the 360 heads. Other wise they are 340/360 heads not std. 318 heads.
Re: 360 performance [Re: erick72] #527544
01/09/10 09:34 PM
01/09/10 09:34 PM
TMP66 Offline
TMP66  Offline
i know i know ive asked before. but i got a 360 im ready to put in my 72 roadrunner/satellite and i keep getting told "oh that car is way to heavy for that baby engine" or that thing wont be fast enough"
HONESTLY ANY ONES INPUT WANTED.
The best input I can think of is...if you like small blocks and have a budget/goal of what you can afford and want to do, go for it.
Do what you want and screw the unsolicited opinions of others.
Re: 360 performance [Re: TMP66] #527545
01/10/10 08:20 PM
01/10/10 08:20 PM
E
erick72 Offline OP
erick72  Offline OP
E
thats basically wht i think i just wanted imput
Re: 360 performance [Re: erick72] #527546
01/10/10 11:01 PM
01/10/10 11:01 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
I would have laid the headers in the engine bay before install.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: 360 performance [Re: MonGoo$e] #527547
01/10/10 11:07 PM
01/10/10 11:07 PM
Manitoba, Canada
Manitoba, Canada
I doubt it'll be much of an issue. I put the headers in my 74 after dropping in the 440, just pulled up on the motor a bit with the engine jack and they slid right in. With a little 360 he will have a lot more room to spare.
Re: 360 performance [Re: DaytonaTurbo] #527548
01/10/10 11:30 PM
01/10/10 11:30 PM
ky.
K
kenworth_goose Offline
K
ky.
Here's what my 68 Dart 360 was/
std bore, 10to 1 KB's
273 rods
508 purple shaft
stock 360 small valve heads
adj rockers
single plane intake
worked 750 dp holley
windage tray
hooker headers
stock torque convertor
rebuilt 904 with a shift kit, nothing else
3.91 suregrip
street tires
full flowmaster exhaust
Car ran 12.40's all day in 90 degree heat.
So don't let anyone tell you they won't run. Had I had the chance to put in a stall and the 4.30's I bought for it it would have gone 11's all day. It ran 1.94 60 foot times so it wasn't taking off very well but pull as hard as a big block on the big end.
Re: 360 performance [Re: kenworth_goose] #527549
01/11/10 12:12 AM
01/11/10 12:12 AM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
The 360 in my sig pic should make well over 400hp/400tq if I ever get it done. As long as your pistons aren't way low in the hole you can simply add Eddy heads/intake/cam down the road when you have the money. I'm sure your 360 as is will do fine in there.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: 360 performance [Re: erick72] #527550
01/11/10 08:49 AM
01/11/10 08:49 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
when I put it in my 5th, I put the headers in first, held them up and out of the way with bungee cords, then dropped the engine in......of course, I also but the tranny in after the motor was in....
Re: 360 performance [Re: patrick] #527551
02/22/10 01:31 AM
02/22/10 01:31 AM
E
erick72 Offline OP
erick72  Offline OP
E
got the headers in! finally! keep trying to get it started by pouring gas down the carb but still nuthing. idk what it is.
Re: 360 performance [Re: erick72] #527552
02/22/10 02:14 AM
02/22/10 02:14 AM
see if the plugs are clean/see if the plugs are getting fire/fill up the carb bowl vents w gas until the AP give a full squirt/reluctor even w magnet w dampener @10 before on #1 compression
Re: 360 performance [Re: RapidRobert] #527553
02/22/10 09:13 AM
02/22/10 09:13 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you haven't touched the distributor since you picked it up from me, make sure I didn't accidentally put in in 180 degrees out...
Page 3 of 4 1 2 3 4
