71 RR switch to halogen sealed beams #527400
11/16/09 12:20 AM
11/16/09 12:20 AM
north wisconsin
shadow456 Offline OP
north wisconsin
is there any problems or anything i need to switch my sealed beams to halogen sealed beams? amps or volts concerns? thanks..
Re: 71 RR switch to halogen sealed beams [Re: shadow456] #527401
11/16/09 11:03 AM
11/16/09 11:03 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I've used halogen sealed beams in 2 of my Challengers, and have not had any problems.
Re: 71 RR switch to halogen sealed beams [Re: JDMopar] #527402
11/16/09 11:38 AM
11/16/09 11:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They actually draw less amps than sealed beams.Have them in my 65 the kids 62 and had them in my 57.Only time you have to worry some is if they have replacement bulbs inside.If you go over a 55/100 watt it might draw too much current.I run 55/100 in my Harleys with no proble,s and one is a 58.Rocky
Chrysler Firepower
Re: 71 RR switch to halogen sealed beams [Re: therocks] #527403
11/16/09 11:46 AM
11/16/09 11:46 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
needs to use relays. The power suck by the halogens won't be drive safe by the original switch. Too much load on them.
Re: 71 RR switch to halogen sealed beams [Re: therocks] #527404
11/16/09 11:48 AM
11/16/09 11:48 AM
Brighton, MI, USA
kb73rr Offline
kb73rr  Offline
Brighton, MI, USA
I've used all sealed beam halogens for years with no issues. You'll like the difference at night.
1973 Road Runner 2006 Grand Cherokee http://www.muskie-lures.com/73roadrunner/index1.htm "An entrance ramp is a terrible thing to waste"
Re: 71 RR switch to halogen sealed beams [Re: kb73rr] #527405
11/16/09 11:49 AM
11/16/09 11:49 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
same as me... everyone down here uses halogens... but WITH RELAYS!
Re: 71 RR switch to halogen sealed beams [Re: shadow456] #527406
11/16/09 04:42 PM
11/16/09 04:42 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
As Nacho mentioned relays may improve the situation, if light output on the current sealed beams is lame. Halogens will help somewhat, but the limiting factor most of the time is the electrical system itself on these old cars. The headlights' power comes from 1) alternator, 2) through bulkhead (power loss), 3) through headlight switch (more power loss), 4) through dimmer switch (more power loss), 5) back through bulkhead (more power loss). Plenty of places for resistance to build up, resulting in lame headlight power, ergo lame light output.
Lots of places (here and elsewhere) to find how to hook up relays to get decent power to the bulbs (whether sealed beams or H4s). One relay for the low beams, one relay for highs, the original power for the bulbs becomes the trigger for the relay. It's actually quite easy to figure out. Probably even some diagrams here on Moparts somewhere. Parts to do it from any auto parts place for less then $10, most likely.
Re: 71 RR switch to halogen sealed beams [Re: MoparMarq] #527407
11/16/09 05:00 PM
11/16/09 05:00 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
