I was looking at Big block Chevy electric water pump choice to use with the Indy's Meziere reverse flow plate that uses a Big block Chevy water pump. I happened to stumble across this kit. Looks like it can be flopped to run on passenger or driver side.
I wonder how the crank pulley spacing would work..I already have the ATI damper that has the Chevy pulley pattern why stop there...
Has anyone tried this? Does anyone see a problem why this could be used?
I dont know, that would be a bunch of stuff sandwiched between the water pump..
-motor plate
-Indy plate
-alt bracket
It might work out good, and other options is nice.
http://www.summitracing.com/parts/CMB-06-0048/?image=large
