Nitrous and stock rods 360 #527094
11/15/09 08:41 PM
11/15/09 08:41 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
How much nitrous can stock 360 rods and cast crank take?
Re: Nitrous and stock rods 360 [Re: skep419] #527095
11/15/09 09:12 PM
11/15/09 09:12 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Depends on how good your tune-up is. Run it way lean or rich and they won't last long.
With a good tune-up 150 shouldn't be much of a problem.
Re: Nitrous and stock rods 360 [Re: skep419] #527096
11/15/09 09:56 PM
11/15/09 09:56 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
As well as your rods and crank your pistons and ring package will be limiting factors.If you can apply the 150 max shot over stages/delayed timed you'll be better off.Make sure you apply timing retard when spraying.
Re: Nitrous and stock rods 360 [Re: solidcam] #527097
11/15/09 10:32 PM
11/15/09 10:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ran 150 shot for a season on a OLD 360 shortblock. Ran 150 shot for along time then put another 75HP to it when I went to a 727 from a low gear 904, had to get my et back. I was no tune up wizard and it lived and I later sold it.
68 Barracuda Formula S 340
Re: Nitrous and stock rods 360 [Re: slantzilla] #527098
11/15/09 10:39 PM
11/15/09 10:39 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Get some tune-ups from Monte Smith, and you will be in good shape.
