Milling block and/or cyl head #526965
11/15/09 07:00 PM
11/15/09 07:00 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
How much can a stock block be decked? How about 452 cast iron heads?
If either of these are cut, how much does the intake side of the head need to be cut? Anything else need to be machined?
Thanks, Brian
Re: Milling block and/or cyl head [Re: '72CudaRacer] #526966
11/15/09 08:01 PM
11/15/09 08:01 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I have two old SS Street Hemi blocks that have been decked around .100"-.120". I wouldn't recommend doing that. On a stock block and heads, I've heard .060" is around the maximum recommended. I prefer to take as little off as necessary. It sounds like you need different pistons to me.
Floyd Lippencott IV
Re: Milling block and/or cyl head [Re: '72CudaRacer] #526967
11/15/09 09:18 PM
11/15/09 09:18 PM
wappinger falls new york
Jimi_Vignogna Offline
i have taken as much as .250 off a stock deck on a block, 452 heads we usually take .110 off the deck side to get them around 63 cc's and .125 plus off the intake side never have any problems.
Re: Milling block and/or cyl head [Re: '72CudaRacer] #526968
11/16/09 01:46 AM
11/16/09 01:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks, Brian
For every .010 off the deck surface the intake side needs to be milled .0123 , whether it comes off the head or the block the heads intake surface needs to be cut ... also note for every .010 off the block deck the valley end rails should be cut , .0123 off the end rails , just like the heads .
I have a 383 that's been decked .018 and a set of heads I was going to use were cut about .040 , with the intake surface cut the required amount , I ended up having to cut .075 off the valley end rails to get the intake tub gasket to fit right .
Re: Milling block and/or cyl head [Re: JohnRR] #526969
11/16/09 12:13 PM
11/16/09 12:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A friend had .160 taken off a 440 to get the 8 to 1 pistons up!!! LOL!!
I have milled a set of 906 .110 also worked good for years till one cracked back in the intake bowel where it was ported a little thin!!
aluminum is the only way to go now!!!
Re: Milling block and/or cyl head [Re: '72CudaRacer] #526970
11/16/09 02:31 PM
11/16/09 02:31 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
One of my smog 440's was .2 in the hole. If I'd been smart I would have used those pistons with a 4.15 crank. Almost as cheap and definetly more effective than decking and then milling 4 head surfaces.
Sheldon
