Which would you buy?????? Opinions??????? #526096
11/14/09 07:40 PM
11/14/09 07:40 PM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Hey guy's I am thinking about buying a set of heads for my car, and was wondering what you'all
would do, go with the Indy EZ's, or the eddy's?
I have some extra cash , I need
to do something with before the end of the year, for tax purposes, and thought I might buy some heads for the old gal.
I am not wanting to rotate the earth or anything like that, just thought I would pick her up a touch. The combination in the car now is killer, when the driver does his job, but like I said,
there is some extra $$$$$$ that need to go.
The only problem I have with new heads, is the angle plugs, I will have problems with my current headers, with clearance issues, and they are fairly new, and I don't want to use the old hammer clearance trick.
Thanks Dave
Re: Which would you buy?????? Opinions??????? [Re: 65racer] #526097
11/14/09 08:09 PM
11/14/09 08:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you are considering a straight plug head then you will need the MP 452.It's actually an Eddy head with straight plugs and an "M" on the head.
I have Indy EZ's and Doug's D452 headers and have no issues with plug clearance at all.
Gus
64 Plymouth Savoy
Dana 60
Re: Which would you buy?????? Opinions??????? [Re: fourgearsavoy] #526098
11/14/09 08:27 PM
11/14/09 08:27 PM
okla.
sam64 Offline
sam64  Offline
okla.
i don't think i would be messing with a champion winning combo,good job by the way.start building a back up motor or something. or you could sell the car to me for your original 40.00s and build a new car.
Re: Which would you buy?????? Opinions??????? [Re: sam64] #526099
11/14/09 08:46 PM
11/14/09 08:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
I guess you should buy heads and headers then lol. I like the idea of building a spare bullet though.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Which would you buy?????? Opinions??????? [Re: Triple Threat] #526100
11/14/09 08:58 PM
11/14/09 08:58 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
CNC Stealth heads... are also straight plug.
Re: Which would you buy?????? Opinions??????? [Re: camdog440] #526101
11/14/09 09:09 PM
11/14/09 09:09 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I like the victors if you have room for the raised exhaust runner. But the EZ is not a bad head either. Was much more impressed with it out of the box than the -1's we picked up. EZ's had cnc bowl blend done and a much taller floor than the -1's. But the victors are like the EZ's with a better exhaust port. I think their max wedge version is a decent head but I think it needs a 2.250 valve to take advantage of the size they cast the bowl area. It's a little big for the 2.2 valve.
But the standard port window victors aren't a bad head at all either. 340 cfm with some mild work is not hard to do at all.
Re: Which would you buy?????? Opinions??????? [Re: camdog440] #526102
11/14/09 09:12 PM
11/14/09 09:12 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
The stealths and/or RPMs would be great, but I am wondering if your performance improvement would be worth the money over your ported cast iron heads. However, the CNC EZs would give you an extra kick you could feel. You could prob use the same headers.
Re: Which would you buy?????? Opinions??????? [Re: 65racer] #526103
11/14/09 09:15 PM
11/14/09 09:15 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Is it still the 383 in the car? I agree I would'nt mess with the combo.
Re: Which would you buy?????? Opinions??????? [Re: DblOJoe] #526104
11/14/09 09:22 PM
11/14/09 09:22 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
hmmm 12k would get you into a nice trailer, and it could be a write off as you are investing back into your "hobby" lol....
I never heard anyone say their combo isnt consistent because of the heads
Re: Which would you buy?????? Opinions??????? [Re: Garceau] #526105
11/15/09 11:21 AM
11/15/09 11:21 AM
TN
65racer Offline OP
65racer  Offline OP
TN
Garceau,
That is a thought, but,,,,,,,,,,,,I won a new 28' Haulmark enclosed, when I won the N/Box championship a couple of weeks ago, also a new Davis custom built golf cart, so I am having to look elsewhere for the tax write off's.
Re: Which would you buy?????? Opinions??????? [Re: 65racer] #526106
11/15/09 11:30 AM
11/15/09 11:30 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
What heads are on the car now ??
Re: Which would you buy?????? Opinions??????? [Re: VernMotor] #526107
11/15/09 11:47 AM
11/15/09 11:47 AM
TN
65racer Offline OP
65racer  Offline OP
TN
What heads are on the car now ?? [/quote
915's, steel head, with no port work, but have been cut a bunch.
Re: Which would you buy?????? Opinions??????? [Re: 65racer] #526108
11/15/09 12:45 PM
11/15/09 12:45 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
No brainer for me...I'd be putting Indy SR's on it for your type of racing and what you are looking to do.Best bracket head and overall performer for the buck.
RIP Monte Smith
Re: Which would you buy?????? Opinions??????? [Re: CompWedgeEngines] #526109
11/15/09 12:48 PM
11/15/09 12:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I woudl go with SR's as well. IMO they are often overlooked anymore but have a world of potential.
Re: Which would you buy?????? Opinions??????? [Re: Al_Alguire] #526110
11/15/09 01:02 PM
11/15/09 01:02 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I run the Edelbrocks on my 65'
Re: Which would you buy?????? Opinions??????? [Re: 65racer] #526111
11/15/09 01:39 PM
11/15/09 01:39 PM
Do you want to keep your intake for the new heads or are you willing to buy and switch intakes ? If willing to switch I would look hard at a set of B1-BS heads with the M.W. intake port size and buy a intake to match or buy a set of Eddy Super Victor heads (the M.W. intake port size ones) and intake to match. That should pick the combination up(as long as the compression stays the same) several tenths and similar MPH
Re: Which would you buy?????? Opinions??????? [Re: Cab_Burge] #526112
11/15/09 03:12 PM
11/15/09 03:12 PM
TN
65racer Offline OP
65racer  Offline OP
TN
Thanks for the input guy's,
The thought of changing the combo engine in the car has never crossed my mind, I have it out to be freshened up as we speak.
This deal is looking for something to build as a back up, who knows maybe it will find itself in the engine bay, for some testing?????????????
I just need to move some $$$$$$$, for tax purposes, nothing more, Uncle Sam is going to me, on my taxes when the if I don't so something.
This is a problem I don't mind having, I deal with it every year, but there is quite a bit more in the sack to deal with this year.
Thanks Dave
Re: Which would you buy?????? Opinions??????? [Re: 65racer] #526113
11/15/09 06:54 PM
11/15/09 06:54 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
I'm surprised that no one has sugested this, but you could just sponsor another racer...me! My crew chief says I wouldn't have any trouble spending it!!
Brian
Re: Which would you buy?????? Opinions??????? [Re: '72CudaRacer] #526114
11/15/09 07:03 PM
11/15/09 07:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Dont let possible spark plug interference be the deciding factor on head choice..
Buy a head that you later can grow into or send out for some major porting to pickup some real E/T.
Go with the Indy's. Later on when you want to go fast..which we all do at some point. You can send them out, have them ported add the matching cam and pickup a half second in E/T.
This is exactly what I did.
Accel makes a shorty plug also.
Re: Which would you buy?????? Opinions??????? [Re: Bob_Coomer] #526115
11/15/09 07:49 PM
11/15/09 07:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I would go with the EZ's best head for the bucks - even if you get the stock intake port - the EZ-1 are max wedge port and can be made to flow around 350+ the eddy's are pretty much maxed out at around 325-330 Best part the EZ's use a standard exhaust port height and location - no header issues
