66 a-body drums to disc question #526021
11/14/09 05:58 PM
11/14/09 05:58 PM
Spring Grove, PA, US
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
I have a 66 Valiant that i am putting a 318 in.. I figured that while i have the slant 6 out i would replace the bushings and torsion bars.. anyway i realized i have the contol arm and spindles from a 74 duster with disc brakes, will these bolt on my car with 9" drums?? the control arms look the same, is the ball joint a different size? I already have an 8 3/4 with 11x2 1/2 in the rear but i figured its better to have more brakes than not enough.
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: 66 a-body drums to disc question [Re: Mr.Mopar] #526022
11/14/09 06:31 PM
11/14/09 06:31 PM
Use the 74 UCA/spindle which does have a larger ball joint. Use your oe LCA and get a lower ball joint for a 74 dart w discs.
Re: 66 a-body drums to disc question [Re: RapidRobert] #526023
11/14/09 06:47 PM
11/14/09 06:47 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
what he said!
lower ball joint is the same for all 73-76 A bodies, drum or disc.
Re: 66 a-body drums to disc question [Re: nomore65BelvJim] #526024
11/14/09 07:36 PM
11/14/09 07:36 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
Thanks for the help guys!
1933 Dodge DP (201)
