Milodon Hemi Spark Plug tube seals w/indy heads..... #526002
11/14/09 05:36 PM
11/14/09 05:36 PM
Anonymous OP
Anonymous OP
SUUUCKKKK, big time !!!rocker stand bosses on the indy alumininum legend hemi heads interfere with the geometry and dont go in straight.there is too much meat on the castings.
also valve cover stud holes are off and don't line up with valve cover holes.
so now i'm grinding on the milodon seals in order to get the proper clearance and geometry to get the tubes to sit in flush with no binding and sparkplugs go in straight.
doesn't indy take any of this into consideration before designing and making this stuff.
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526003
11/14/09 05:44 PM
11/14/09 05:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey Chris
Are those just the anodized blue aluminum ones? Do they use any kind of gasket, seal or O-ring? I didnt think so..I was thinking they just push in, and the soft aluminum conforms to the counter bore etc correct?
I hate to sound stupid, but I dont know, or never seen a installed set except a few pics. I was looking at getting a set for My MP/Edelbrock heads (M2 casting) but not sure if the would fit or not..I have the standard MP Hemi tubes and O-rings I hope to use with the stamped steel chrome valve covers.
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... [Re: Bob_Coomer] #526004
11/14/09 06:43 PM
11/14/09 06:43 PM
Anonymous OP
Anonymous OP
Hey Chris
Bob, they are the blue anodized ones with the countersunk recessed internal o ring, which press in the counterbore, yes there is a o ring.
i put them in the freezer to get trhem to shrink and they went in but now i have to wait until they go back to room temperature so the spark plug tubes can slide into them. right now they are tight since they are frozen.
hope these things work, pulling spark plugs and all that oil really bites.
my only concern afterwards is if i need to pull out a tube at the track these seals don't come out of the counter sunk bore, that means pulling off the valve cover.
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526005
11/14/09 10:35 PM
11/14/09 10:35 PM
Anonymous OP
Anonymous OP
just finished installing these PITA pieces.
never again will i buy these things.
i'll deal with the oil next time around if i ever need a set.
no matter how you drive them in, they are always cocked when you put in the sparkplug tube.
you go to align them and they pull out.
4.5 hours to get them right.
dont know how i'm going to get these valve covers off when i need to adjust rockers.
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526006
11/14/09 10:40 PM
11/14/09 10:40 PM
Anonymous OP
Anonymous OP
Hemi-itis is going to get a little for talking me into these seals.
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526007
11/15/09 12:28 AM
11/15/09 12:28 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You got the blue ones Ya shoulda got the red ones or is it the other way around
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... [Re: hemi-itis] #526008
11/15/09 08:03 AM
11/15/09 08:03 AM
Anonymous OP
Anonymous OP
all i know is i got the good ones and i got the shaft! lol not driveshaft. < see the hammer thats what i was doing for 4.5 hours to get them in straight. in ans out ,in and out.
well Hemi-itis they are in so now you can check my plugs.
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526009
11/15/09 10:18 AM
11/15/09 10:18 AM
hemi-itis Offline
hemi-itis  Offline
Nice job SSR,look at how much $$$$$ you saved by doing it yourself
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... [Re: hemi-itis] #526010
11/15/09 11:07 AM
11/15/09 11:07 AM
Anonymous OP
Anonymous OP
you'd work for eats correct?
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526011
11/15/09 11:56 AM
11/15/09 11:56 AM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
It's the casting, not the tube seals causing them to not be straight on the indy heads. They really need some clearance machining to fit properly. Bob, the new M2 Castings will need some machining as well. Some fit ok, some don't as the casting doesn't have enough clearance. The seals work just fine with the old MP heads.
Post deleted by Defbob [Re: CRE2004] #526012
11/15/09 02:59 PM
11/15/09 02:59 PM
Anonymous OP
Anonymous OP
Re: Milodon Hemi Spark Plug tube seals w/indy heads..... #526013
11/15/09 03:12 PM
11/15/09 03:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
every Indy and stage V head I have alrady has an O ring in the plug hole and didn't need the KB seals.
You are Correct Fred,the press in seals are expensive and a pita.They tend to come out and sometimes wont let the plug tube seat.They are mainly for stock style heads.Indy and Stage Five have solved that issue by grooving and o-ring the pocket.
