Re: 383 VS 383HP
[Re: TMBOOTS]
#525926
11/14/09 05:06 PM
11/14/09 05:06 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
there were 4 383's available in 1969
383 2bbl 290HP , 9.2 ADVERTISED , actual was lower , will have an "R" stamped on the ID pad
383 4bbl 330HP , 10.0 ADVERTISED , actual was lower , anything that could be order with a 383 except below , no HP stamped on ID pad , Road Runner and Superbee with A/C should have this engine.
383 4bbl 330HP , 10.0 ADVERTISED , actual was lower , Dart and Barracuda ONLY , should have HP on the ID pad , I'll have to look at my car to confirm
383 4bbl 335HP , 10.0 ADVERTISED , actual was lower , Road Runner and Superbee ONLY , this one will be stamped HP on the ID pad .
The difference between A body engine and the 335HP engine is the exh manifolds , the difference between these and the 330 HP engine is the 330HP engine has the same cam as the 2bbl 290 HP engine , will have HP exh manifolds.
I'm sure someone will correct me .
Re: 383 VS 383HP
[Re: TMBOOTS]
#525928
11/14/09 05:09 PM
11/14/09 05:09 PM
JohnRR
That's my dart. It has a standard 383 in it now with a epoxy repaired block crack , so I was looking for another engine or block, and I came across the 383HP.
unless the HP is low miles and ready to run ORIGINAL you'll need to rebuild it and it won't matter what it WAS , you can't buy EXACT replacement pistons so you'll have even LOWER compression ratio unless you deck the block , which could remove the stampings you will be paying EXTRA for , and an exact replacement cam is not available ... otherwise have fun
If it's been rebuilt no telling what you'll get
Re: 383 VS 383HP
[Re: JohnRR]
#525929
11/14/09 07:51 PM
11/14/09 07:51 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
6 quart pan with windage tray, Magnum cam, heavier valve springs with dampers,4bbl intake with AVS carb, hp exhaust manifolds, 10-1 pistons, tri-metal rod bearings.
Re: 383 VS 383HP
[Re: JohnRR]
#525930
11/15/09 03:06 AM
11/15/09 03:06 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
383 4bbl 335HP , 10.0 ADVERTISED , actual was lower , Road Runner and Superbee ONLY , this one will be stamped HP on the ID pad . Available in any 69 B body with four speed
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: 383 VS 383HP
[Re: 69CoronetRT]
#525931
11/15/09 03:35 AM
11/15/09 03:35 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
The 383-2 bbl motor had dished pistons,no windage tray or baffles.429 lift cam and the "red" springs wo/damper.I think the 330 h.p. cam was ground on 115 LC instead of the 335 h.p.which was 113 LC.Both had the same.455 lift.
Leave the gun.......take the Cannoli's....Mike
Re: 383 VS 383HP
[Re: mike s]
#525932
11/15/09 12:14 PM
11/15/09 12:14 PM
JohnRR
According to my 69 FSM the 330HP has the same cam as the 383 2bbl , which is the same cam as the 440 350HP engine . also If I remember correctly I took a 402 pan off a 68 383 2bbl that i pulled from one of my untouched winter beaters , it had the 402 pan it it , which had baffles ...
Dave , no 6qt. pans on the 383 , they all used the 402 pan in a B body and E body
Re: 383 VS 383HP
[Re: JohnRR]
#525933
11/15/09 06:37 PM
11/15/09 06:37 PM
quickd100
nielsville, minn.
Mine came with one,...I bought my '69 Road Runner with 30,000 miles on it, it had one on when I bought it. Maybe the previous owner installed it. Bought it in '76.Dave
Re: 383 VS 383HP
[Re: JonC]
#525935
11/15/09 07:31 PM
11/15/09 07:31 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
HP's also had a windage tray. 70's had a 5 qt pan.
Mine had a Holley with the N96
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 383 VS 383HP
[Re: quickd100]
#525936
11/16/09 01:25 AM
11/16/09 01:25 AM
JohnRR
Which 6 qt. pan was it , the 66-69 HEMI pan or the later 70-71 pan ? obviously the 70- 71 was not available on anything in 69 , the other pan could have been a factory goof , the problem was there was no 3/8" pickup available for the 66-69 hemi pan ...
I say previous owner installed it , not factory
