383 swap to 440 Torque Converter Work? #525596
11/14/09 08:47 AM
11/14/09 08:47 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I'll be swapping a 1966 dated 383 to a 1972 steel crank 440. Will my 383 Torque converter work? Im concerned about balancing issues.
DJ
Re: 383 swap to 440 Torque Converter Work? [Re: CYACOP] #525597
11/14/09 09:02 AM
11/14/09 09:02 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You also may have a fit problem with spline count on input shaft and diameter of converter snout register to crankshaft center.
Re: 383 swap to 440 Torque Converter Work? [Re: buildanother] #525598
11/14/09 09:26 AM
11/14/09 09:26 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
If the current 383 converter never comes out of the transmission, it seems the snout shaft diameter will be the only issue. What about weights welded on the torque converter? I havent removed the 383 yet so I dont know what it looks like yet.
Re: 383 swap to 440 Torque Converter Work? [Re: CYACOP] #525599
11/14/09 09:53 AM
11/14/09 09:53 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
DJ
I would be concerned too since the cranks are different weights. I'd be looking for a converter from a steel crank 440.
Re: 383 swap to 440 Torque Converter Work? [Re: CYACOP] #525600
11/14/09 09:54 AM
11/14/09 09:54 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
There should be no weights if both are steel (forged shaft) engines.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 383 swap to 440 Torque Converter Work? [Re: CYACOP] #525601
11/14/09 05:04 PM
11/14/09 05:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The convertors will work (both applications are neutral balance). the 66 has different transmission splines than the 72 transmission so you will have to keep the 66 convertor with the 66 transmission or the 72 convertor with the 72 transmission (which I think you know). Also the flexplate convertor bolt pattern could be different so check that.
Sheldon
