Body Numbers Locations on '68 Road Runner #525569
11/14/09 04:31 AM
11/14/09 04:31 AM
USA
JoesMopar Offline OP
USA
Anyone know where the body numbers are stamped on a '68 Road Runner to match the panels to the VIN? Thanks
Re: Body Numbers Locations on '68 Road Runner [Re: JoesMopar] #525570
11/14/09 07:41 AM
11/14/09 07:41 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Don't know of them stamped any where on 68. on your data plate you will have a von # not your vin, this von # is stamped on the inside of your radiator suppt, usually between rad and supt, in otherwords look between your radiator and radiator supt and you should see these von #s stamped there, also on drivers side trunk rail under rubber trunk seal your von # should be there.. Your build sheet should have this # on it also. (Vehicle Order #). I have two 68 coronet rts and have been all over them, with no Vin #s stamped anywhere on body.. only vin is on dash Vin. 69 this all changed..
Re: Body Numbers Locations on '68 Road Runner [Re: 268RTs4ME] #525571
11/14/09 07:57 AM
11/14/09 07:57 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Correct, NO vin #'s stamped on any 68 Mopar. You need the fender tag or build sheet to match the VON as stated above.
Re: Body Numbers Locations on '68 Road Runner [Re: 268RTs4ME] #525572
11/14/09 10:57 AM
11/14/09 10:57 AM
USA
USA
Thanks for the info.
I have the build sheet, but not the fender tag.
On the top of the build sheet it has:
Sequence Number
B | 200478
Shipping Order
621 | 218453
Which of those is the VON? I would think the S/O would be but not sure what the Sequence number means.
Re: Body Numbers Locations on '68 Road Runner [Re: 268RTs4ME] #525573
11/14/09 11:20 AM
11/14/09 11:20 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: Body Numbers Locations on '68 Road Runner [Re: ademon] #525574
11/14/09 11:26 AM
11/14/09 11:26 AM
USA
USA
Hey, on your Road Runner the center of the hood is blacked out, is that considered the SPL. Paint Treatment 508 code specifying Performance Hood Paint?
Mine has this code and was hoping that's what it is because I really like that.
