Re: Aluminum vs Steel Replacement Driveshaft Question
[Re: SCATPK]
#525475
11/14/09 11:08 AM
11/14/09 11:08 AM
Posts: 4,210 New York
polyspheric
New York
It's an improvement, but it's worth very little. Don't expect to see it on your timeslip. Why: 1. Small mean radius of gyration = low moment of inertia (compared to a clutch disc, converter or ring gear) 2. Low RPM through almost all the race (compared to anything in front of the transmission)
Boffin Emeritus
[Re: SCATPK]
#525479
11/14/09 03:18 PM
11/14/09 03:18 PM
Posts: 22,707 Bitopia
jcc
Bitopia
I would also assum an alum driveshaft would do less damage then a steel one upon a driveshaft failure, with or without a loop, and CF doing the least damage.
[Re: jcc]
#525480
11/14/09 04:13 PM
11/14/09 04:13 PM
I went with a mark williams aluminum driveshaft with 1350 yokes on both ends and it was a smart choice. picked up a little, MW has great customer service and i'd buy another one in a heartbeat. i like the light weight over the steel shaft.
Re: Aluminum vs Steel Replacement Driveshaft Question *DELETED*
[Re: jcc]
#525484
11/14/09 06:57 PM
11/14/09 06:57 PM
polyspheric
New York
Post deleted by polyspheric
Boffin Emeritus
[Re: polyspheric]
#525485
11/14/09 08:15 PM
11/14/09 08:15 PM
Quicktree
Since alum usually requires a larger(next) diameter, it likely would be stiffer
No, aluminum is far less stiff than steel and needs the diameter to even be comparable; more wall thickness makes up the remaining difference.
my 3.5" aluminum shaft is rated to over 1000hp
