Re: 4.500 BB Engine Blocks????????
[Re: supercomp]
#525307
12/04/09 10:13 PM
12/04/09 10:13 PM
Posts: 627 IN
BIG BEAR
IN
BigBear any word on a low deck casting? Steve
Sorry for the hijack Lane!
Don't worry bud, she's acomin! So start saving now
Why did you quit bushing the lifter bores? We use pushrod oiling so that means another $400.00 for a block.
?????? I'm not sure I know what you mean
[Re: supercomp]
#525311
12/04/09 11:18 PM
12/04/09 11:18 PM
Posts: 627 IN
BIG BEAR
IN
[Re: supercomp]
#525313
12/05/09 12:09 PM
12/05/09 12:09 PM
Posts: 16,932 NC
440Jim
NC
I vote bushed. Won't hurt even if you don't need them, but if you do they are there. As more people build more hp they need indivigual shaft rockers.(pushrod oiling)
Help me understand by clarifying that. I thought for pushrod oiling you need oil to the lifter, so unbushed should work? And if you put solid bushings in (without an oil hole), then no oil would go to the lifter and you couldn't pushrod oil.
1) Unbushed 2) Solid bushing (no oil hole) 3) Bushings with a small oil hole.
[Re: 72chrgrally]
#525314
12/06/09 12:07 PM
12/06/09 12:07 PM
Posts: 627 IN
BIG BEAR
IN
Alright my penny jar has a purpose! Please keep us up to date on this. Thanks! Steve [/quote
![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 440Jim]
#525315
12/06/09 08:51 PM
12/06/09 08:51 PM
Posts: 627 IN
BIG BEAR
IN
I believe your right Jim. You would need to oil the lifters in order to get oil thru the push rod.
[Re: BIG BEAR]
#525316
12/06/09 11:11 PM
12/06/09 11:11 PM
Posts: 3,441 Mo.
supercomp
Mo.
to much oil without bushing and small hole and lack of oil pressure.
[Re: supercomp]
#525317
12/07/09 08:54 AM
12/07/09 08:54 AM
Posts: 627 IN
BIG BEAR
IN
What about restricting the oil gallies?
[Re: supercomp]
#525320
12/07/09 10:24 AM
12/07/09 10:24 AM
Posts: 627 IN
BIG BEAR
IN
Ask around and see what the big builders think. If it doesn't raise the price I think they will vote for bushings because they are better in a high lift race engine.
If you ADD anything, it will always cost more. The key is to keep to cost as low as possible to the end user. More than likely all the blocks that we cast in the future will have the bushings installed, however you may see a slight price increase because of it.
[Re: blownzoom440]
#525321
12/07/09 10:26 AM
12/07/09 10:26 AM
Posts: 627 IN
BIG BEAR
IN
my block #33 came unbushed and i will be restricting the oil at the back of the block.i only use a 650 lift roller.milodon single line,melling HV pump.20/50 oil.
Thanks Metal Storm, We were wondering what number you had. Please keep us informed of the build. ![](/ubbthreads/images/graemlins/beer.gif)
