Re: Moroso Small Blk Water Pump
[Re: Scamp408]
#524782
11/13/09 09:45 AM
11/13/09 09:45 AM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
The whole pump not the motor for the stk pump. How many guys use them for street? How does it work ? Poss some Pics?
Thats what I use on 2 motors I have built. As long as you have a good alternator you shouldn't have any problems. The one I put on my buddies truck has been on there for about 4 years now and he drives it to and from the track or where ever else he takes it and I drive mine also with no issues.
[Re: Scamp408]
#524783
11/13/09 09:53 AM
11/13/09 09:53 AM
Posts: 1,532 off the grid
340B5
off the grid
[image] [/image] Cools 180* to 140* in 3 minutes. Draws 15 amps, not the advertised 7amps. No airlock problems. I like it.
Yeah, it's got a smallblock.
[Re: 340B5]
#524784
11/13/09 10:06 AM
11/13/09 10:06 AM
Posts: 4,979 new jersey usa
11secdart
new jersey usa
I saw one on a acquaintances small block Satelite this past weekend and I like it and am thinking about putting on my Dart. I had a Meziere but had problems with it and went back to a stock pump setup.
[Re: Mr 5 Speed]
#524787
11/13/09 10:28 AM
11/13/09 10:28 AM
11secdart
new jersey usa
Hey Emilio, good seeing you guys also. My car runs pretty cool and consistent but it would be nice to cool it down quicker especially in the later rounds when there rushing us. How was the Shakedown? I went to Atco for the Mopar Meet.
[Re: 11secdart]
#524788
11/13/09 10:46 AM
11/13/09 10:46 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Looks like its alot easier than a Mezziere when it comes to makeing an alternator bracket. Whats a used SB mezziere pump worth lol.
68 Barracuda Formula S 340
[Re: 1976 Aspen]
#524791
11/13/09 01:20 PM
11/13/09 01:20 PM
Bad340fish
Tulsa OK
19GPM vs 55GPM from the Meziere, no problems there from any moroso users?
[Re: 1976 Aspen]
#524794
11/13/09 03:49 PM
11/13/09 03:49 PM
Bad340fish
Tulsa OK
Jegs has it listed as 19 GPM but Summit said 35GPM. I thought 19 seemed a little low.
[Re: Bad340fish]
#524795
11/13/09 09:40 PM
11/13/09 09:40 PM
Posts: 814 in front of the computer
80arrow
I could take that mezziere off your hands possibly.
[Re: Bad340fish]
#524798
11/14/09 01:14 PM
11/14/09 01:14 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I have one of these..i believe it is actually 19, not 35 like the more expensive units are. It fits up nice and looks good, but doesnt pump a ton of water, Imo. I have gotten by with mine, but would actuualy like something stouter that is a bolt on.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Scamp408]
#524800
11/14/09 01:54 PM
11/14/09 01:54 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
This is right off of Summits website.
large image $279.95
+ wishlist + compare Water Pump, Electric, 30-37 gpm, Billet Aluminum, Black Anodized, Mopar, Small Block, Each Application Specific Part: Check Application Estimated Ship Date: 11/16/2009Email this page Share OverviewApplicationShow All Brand Moroso Manufacturer's Part Number 63565 Part Type Water Pumps, Electrical Product Line Moroso Billet Aluminum OEM Mount Electric Water Pumps Summit Racing Part Number MOR-63565 Pump Material Aluminum Pump Finish Clear anodized Flow Rate @ 12 Volts (gpm) 30-37 GPM Hose Adapter Required Yes Hose Adapter Included No Inlet Hose Size (in) 1 in. Overall Depth (in) 5.500 in. Amp Draw 7.00 amps Quantity Sold individually.
Add more power and cooling to your engine. These electric water pumps move up to 21 percent more coolant through the system than any competing pump. They mount in the stock location with stainless steel mounting hardware and work with both 12 V and 16 V systems. They feature a billet aluminum pump housing and impeller, heavy-duty windings, long-life brushes, a stainless steel shaft, sealed ball bearings, a blue powdercoated outer case, and a high-temperature Viton seal. They're available for a variety of engines.
I tried to get the picture but it didnt work.
