What engine paint did you use? #524409
11/12/09 09:10 PM
11/12/09 09:10 PM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I just got back from my machine shop and I was not happy with the quality of the paint on my block. I supplied the paint to him, I used Dupli-Color engine enamel Chrysler Orange (DE 1622) and it came out flat and dull. My machine shop had me come down and look at because he stated that he was not impressed with the quality. There are 3 coats of paint on it now, and the paint came out very thin. He says he will repaint it for free with the orange he stocks (chebby orange) if I would like but, I do not want that, even though they look about the same. What brand are you guys using? Did I just get a "bad can of paint"
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: What engine paint did you use? [Re: jrlegacy23] #524410
11/13/09 01:04 AM
11/13/09 01:04 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used the duplicolor hemi orange on mine as well and it was crap. Not the glossiest but not flat either, that part I had no problem with. The paint is so thin, super low solids paint, takes 100,000 coats to get full coverage.
Re: What engine paint did you use? [Re: DaytonaTurbo] #524411
11/13/09 01:37 AM
11/13/09 01:37 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
VHT, though not Hemi orange. I think the VHT is kind of thin too. I followed the directions on the can, 2 light coats, one medium-wet coat, bake at 200* for 1 hour (except for the block itself of course). I've had good results with everything that has been cured.
Each part was painted individually and I'll have to go back before it goes in and get all the parting lines. Or not. I like that it will all come apart easily. I sure hope I don't have to do that though.
Best of luck.
Re: What engine paint did you use? [Re: Chilort] #524412
11/13/09 02:19 AM
11/13/09 02:19 AM
Cooperstown, NY
Cooperstown, NY
Ya, he has three coats on it so far and it looks so thin, it only looks like he did 1 skim coat. Is there an engine paint that looks good and will cover in a few coats?
Re: What engine paint did you use? [Re: jrlegacy23] #524413
11/13/09 02:23 AM
11/13/09 02:23 AM
Manitoba, Canada
Manitoba, Canada
I saw plasti-kote also sells a hemi orange engine paint. Anyone try that brand? Sure can't be any worse than the dupli-color.
Re: What engine paint did you use? [Re: jrlegacy23] #524414
11/13/09 02:36 AM
11/13/09 02:36 AM
Clinton Twp. Michigan
coronet1966d Offline
this was all done with dupli-color hemi orange i primed the surface and put about 4 coats on. im thinking about clearing over the paint too for more of a shine
Re: What engine paint did you use? [Re: coronet1966d] #524415
11/13/09 02:58 AM
11/13/09 02:58 AM
Cooperstown, NY
Cooperstown, NY
After doing a little research (which I did not have time to do when I posted this) I see I am beating a dead horse. Sorry guys
But anyways, There were a couple post that guys used plastikote and it looked a nicer than the Duplicolor. Here was the picture that was posted of plastikote
Re: What engine paint did you use? [Re: jrlegacy23] #524416
11/13/09 08:18 AM
11/13/09 08:18 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I found back in the spring while at Autozone that Rust-Oleum now has a Chrysler Hemi orange part #248957 so I tried it. It has high solids applies easily and covers good. It has held up good so far.
Re: What engine paint did you use? [Re: Mopar73340] #524417
11/13/09 08:49 AM
11/13/09 08:49 AM
scratchnfotraction Offline
that dupli color hemi orange is what i used
stock hemi ornage is not that glossy IMO
too glossy and it look chebby orange
I painted the vc with rustolium satin black with a brush..they turned out great..but the 35 yr old vc still show there age and rust pitts
I have painted the frame,under hood,inside cab,under side of inner fenders with rustolium gloss black with an HVLP gun and it looks very good IMHO
I did the 2 cowls and the hood of the stepside with the satin and it looks great also
the PPG engine paint IIRC is the good stuff for engines but pricy
I kinda like the dull look of the duplicolor hemi orange and used 4 cans on my 440 so far,have a 5th can for touch up as it goes together
I will be looking at the rustolium hemi orange for the SB though,just to see what it looks like when done
just my but to glossy is chebby colors
Re: What engine paint did you use? [Re: scratchnfotraction] #524418
11/13/09 09:21 AM
11/13/09 09:21 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
plasticoat is by far the best spray bomb on the market for color, coverage and durability.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: What engine paint did you use? [Re: MOPARMIKE69] #524419
11/13/09 09:51 AM
11/13/09 09:51 AM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
The problem I've had with the Duplicolor is flaking in spots after about a year. I'm currently pulling my motor back out and re-doing cam and paint. I thought about using Eastwoods engine paint, but think I'll use Duplicolor again with primer under it..The gloss/flat issue doesn't bother me, I just want it to stay on there..
Re: What engine paint did you use? [Re: donbarnes] #524420
11/13/09 10:09 AM
11/13/09 10:09 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
You guys are over tkinking this!! Just go to the DODGE dealership and buy FACTORY engine paint across the counter!
Re: What engine paint did you use? [Re: 68GTS383] #524421
11/13/09 10:23 AM
11/13/09 10:23 AM
never thought about paint from the dealer
I will stop by and see what they say today after work..
you might be right,ma mopar used it with good results
Re: What engine paint did you use? [Re: 68GTS383] #524422
11/13/09 10:44 AM
11/13/09 10:44 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
If you are referring to the MP paint, lets hope they have addressed the issue of the paint not coming out of the can when sprayed.
Re: What engine paint did you use? [Re: jrlegacy23] #524423
11/13/09 11:01 AM
11/13/09 11:01 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
After reading up on the best spray bombs here on Moparts, I bought a case of the Duplicolor 1622 for my '71 GTX'x 440. I sprayed a set of valve covers after I had them hot tanked and then scuffed, along with a coat of Duplicolor high temp engine primer they look great! Not too dull, not too glossy... The can I used was sooooo much better than the old MP crap.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: What engine paint did you use? [Re: Blues_Cuda] #524424
11/13/09 11:10 AM
11/13/09 11:10 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Do you want the REAL color or just a good lookin glossy show shine (but not OEM)color ? For those lookin for the OEM type paint contact Frank Badalson for the CORRECT color and yes , it should not be glossy like most spray cans . I have also use the Plasticoat paint but it seemed a bit too orange and glossy but I think its the next best choice.
Re: What engine paint did you use? [Re: THESHAKERPROJECT] #524425
11/13/09 12:29 PM
11/13/09 12:29 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Re: What engine paint did you use? [Re: 70440+6bbl] #524426
11/13/09 12:46 PM
11/13/09 12:46 PM
Athens, Greece
Pyper70 Online content
Pyper70  Online Content
Athens, Greece
I used the MP paint from the Dealer...Street Hemi Orange...Race was too Dark...(or was it the other way around?!?!?)
My stroker block is getting Dupont sprayed on it. HVLP style...It looks great, it has chemicals in it that make it last longer, and I dont need to clear it. The paint lays down more evenly.
If there was only a way to pour the paint in a can and pressurize it, make my own spray bomb...I would
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: What engine paint did you use? [Re: Pyper70] #524427
11/13/09 01:15 PM
11/13/09 01:15 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Race Hemi Orange is lighter/brighter than Street Hemi Orange. 1957 Omaha Orange is the closest match to Race Hemi Orange that I have found.
You can put automotive paint in spray cans actually...there are a few shops around the St. Louis, MO that do that. I believe it was $19 a can last time we had it done. (Assuming you provide the paint.)
Re: What engine paint did you use? [Re: MOPARMIKE69] #524428
11/13/09 01:22 PM
11/13/09 01:22 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Do you want "Pretty" or do you want "correct"? If you want Correct, get your paint from Frank Badelson. He has all of the factory flavors in stock.
*When describing Race Hemi Orange most would call it a "pumkin" Orange with a more yellowish cast rather than the reddish cast of Street hemi Orange. It was used on all 62,63,&64 Max Wedge engines, and all Hemis (Street & Race Hemi's) from 1964-1968. There may have been some late 68 Street Hemis that recieved Street Hemi Orange but to date I haven't seen a proven original.
