Removing reverse lever on 833 #524171
11/12/09 02:45 PM
11/12/09 02:45 PM
Hawaii
Dodgeballs Offline OP
Hawaii
The part where the shifter linkage goes snapped off on my 18 spline 833.
To pull it out, do I need to remove the reverse idler shaft? If I do, is there a trick to doing it without the tool shown in the service manual?
thanks
Re: Removing reverse lever on 833 [Re: Dodgeballs] #524172
11/12/09 03:16 PM
11/12/09 03:16 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I made one out of a coupler nut and threaded rod or something a few years ago. It has to be pushed out from inside case IIRC.
Re: Removing reverse lever on 833 [Re: buildanother] #524173
11/12/09 03:51 PM
11/12/09 03:51 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
did that same thing, it is easy to see what the tool in the FSM is doing. Just make one out of 1/2-13 bolt & coupler nut
Re: Removing reverse lever on 833 [Re: 6T6Cuda] #524174
11/13/09 10:08 AM
11/13/09 10:08 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The tool in the FSM is the same tool that is used for pulling the shift shaft seal on a 904/727 , it's a pain to use though as it slides all over the place
Re: Removing reverse lever on 833 [Re: Dodgeballs] #524175
11/13/09 01:46 PM
11/13/09 01:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I used a piece of round rod (about 5/8" dia.) about a foot long and bent a 90 in it at a point where it will fit in the case and rest against the front edge with one end touching the shaft. Now its a lever. Lightly hammer the end and it will push out the shaft.
Re: Removing reverse lever on 833 [Re: Dodgeballs] #524176
11/13/09 01:49 PM
11/13/09 01:49 PM
Hawaii
Hawaii
Thanks for the info. I'll give it a try
