Re: does kick down rely on engine performance?
[Re: Andrewh]
#523661
11/11/09 07:35 PM
11/11/09 07:35 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
it is not really a kickdown linkage...it is a throttle pressue linkage.
what year is the car and trans...
part throttle kickdown did not become available until a certain year...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Andrewh]
#523664
11/11/09 07:59 PM
11/11/09 07:59 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Older 727's when you rug it is would downshift all the way to first. Part throttle kickdown (from 3 to 2) first showed up in /6 trannies in 1967. LA got it around 70/71. Big block 727 got it much later. Make sure you adjust the rods/levers properly. There is a difference of rods between 2bbl and 4bbl,and also when swapping from the original motor to the 5.9 you have now.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: Andrewh]
#523667
11/11/09 08:18 PM
11/11/09 08:18 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The TP lever on the '65 transmission is longer than that used on most later units, if you can try to find the lever from the original Durango and it should work like the original.
[Re: Andrewh]
#523669
11/11/09 08:25 PM
11/11/09 08:25 PM
Andrewh
