rear end studds #523255
11/11/09 01:06 PM
11/11/09 01:06 PM
nc
E
earthmover Offline OP
E
nc
could some one tell me where I can get the screw in studds for the moser axles I some how broke 2 ..I rem. seeing them in jegs or summit along time ago now they are not in there.....
Re: rear end studds [Re: earthmover] #523256
11/11/09 01:25 PM
11/11/09 01:25 PM
Do you have access to a bolt and nut comapny that stocks grade 8 1/2x20x3 inch allen head bolts? If so that is what I have used instead of paying the price of packageing, shipping and the name brand form one of the comapny that sell the screw in "axle studs"
Re: rear end studds [Re: Cab_Burge] #523257
11/11/09 01:28 PM
11/11/09 01:28 PM
nc
E
E
nc
yea I thought about that just didnt know for sure I'll take 1 with me and see what they come up with ...thanks
Re: rear end studds [Re: earthmover] #523258
11/11/09 02:29 PM
11/11/09 02:29 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Unless you did something odd to break them, I would NOT recommend reinstalling new 1/2" studs. I would make the switch to 5/8" for the extra strength. Over the years I have personally watched two cars break wheel studs on the launch and drive left into the guard rail. Both had 1/2 studs.
Also if two broke while racing, it could have overstressed the other three, making them weaker. If I had to use 1/2" studs, I would replace all five.
I have access to a Moser dealer to get studs if you need them.
Scott
Re: rear end studds [Re: Cab_Burge] #523259
11/11/09 06:23 PM
11/11/09 06:23 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
An axle stud has a narrow head to clear Mopar brake shoes. Standard hardware store bolts rub.
I stock 3" screw in stud kits for $20 set.
Re: rear end studds [Re: ProStDodge] #523260
11/11/09 09:33 PM
11/11/09 09:33 PM
madison, ohio
modified1090 Offline
madison, ohio
Scott
i broke a couple years ago and watched wheels come off a car on the starting line at norwalk once. i made the switch to the 5/8 its cheap compared to the damage that could be caused by the 1/2 breaking
