ECU/COIL #523170
11/11/09 10:27 AM
11/11/09 10:27 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
I will be using the Chrome ECU on my 69RR
What Coil should I be using, will a stock one do it ??
Re: ECU/COIL [Re: TOMRR] #523171
11/11/09 10:54 AM
11/11/09 10:54 AM
yes
Re: ECU/COIL [Re: RapidRobert] #523172
11/11/09 11:29 AM
11/11/09 11:29 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Re: ECU/COIL [Re: TOMRR] #523173
11/11/09 11:56 AM
11/11/09 11:56 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
any coil you want.
personally, MP or Blaster 2 would it be my choices ( they are both the same units ). They will match better the chromed box purpuose for about same stock prices
Re: ECU/COIL [Re: NachoRT74] #523174
11/12/09 03:16 AM
11/12/09 03:16 AM
Burkesville Ky.
gerty Offline
gerty  Offline
Burkesville Ky.
If you use a blaster coil and chrome box will the stock dual ballast resistor be ok?
Bob
Re: ECU/COIL [Re: gerty] #523175
11/12/09 09:57 AM
11/12/09 09:57 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
yep- thats what I'm driving with!!!
Re: ECU/COIL [Re: 71_deputy] #523176
11/12/09 01:04 PM
11/12/09 01:04 PM
Valencia, España
Valencia, España
Me too, but even better if use the 1/4 ohms single resistor. MP have them, MSD coils comes with it in some cases. The smaller dual resistor is as far I remmeber 1 ohm.
would love to get at least .5 ohms dual resistor.
Re: ECU/COIL [Re: NachoRT74] #523177
11/12/09 11:41 PM
11/12/09 11:41 PM
Burkesville Ky.
gerty Offline
gerty  Offline
Burkesville Ky.
Thanks guys
