Page 1 of 3 1 2 3
Where did this 426 Hemi come from? #523032
11/11/09 01:03 AM
11/11/09 01:03 AM
Texas
berrost Offline OP
berrost  Offline OP
Texas
I am about to put a non-numbers matching 426 Hemi into my 1966 Belvedere II Hemi car but would like to know where this donor came from, i cant decode the engine number - help!
Date: 5-19-69
Eng ID: 7C219753
Re: Where did this 426 Hemi come from? [Re: berrost] #523033
11/11/09 01:06 AM
11/11/09 01:06 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Got a photo of the partial VIN?
Re: Where did this 426 Hemi come from? [Re: Alaskan_TA] #523034
11/11/09 01:12 AM
11/11/09 01:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Where did this 426 Hemi come from? [Re: berrost] #523035
11/11/09 01:37 AM
11/11/09 01:37 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Date: 5-19-69
Eng ID: 7C219753
On a 66 there are no stamped vin numbers on the block. All cars 1967 and down actually. So if you found a 66/65 casted block it would be "numbers matching" in the 66 sense.
Usually 66/65 blocks go for less than 69's. It should not be very hard to trade across a 66 for 69 block in equal condition.
You can ask here what casting dates are typical found/accepted for Hemi cars near your SPD date.
Re: Where did this 426 Hemi come from? [Re: autoxcuda] #523036
11/11/09 01:40 AM
11/11/09 01:40 AM
Texas
berrost Offline OP
berrost  Offline OP
Texas
Thanks and I agree, still want to know where this block came from
Re: Where did this 426 Hemi come from? [Re: berrost] #523037
11/11/09 01:58 AM
11/11/09 01:58 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The first "7" in the vin must be a typo. The second digit is a G, so it is out of a B-body from the St. Louis plant for sure.
Any other stampings on it? That would narrow it down some more.
Re: Where did this 426 Hemi come from? [Re: Alaskan_TA] #523038
11/11/09 02:11 AM
11/11/09 02:11 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
64-67 Hemis lacked VIN#'s.
Speaking on 66/67 Street Hemis you would see the year code, cubic inches, assembly date, build sequence, and any other symbols denoting special opperations (OS bores, etc.) on the machined pad opposite of the distributor.
For instance a 66 Hemi engine pad might look like this:
BH 426 HP
10 14 07
Breaks down as:
B = 1966 model year install
H = Hemi Engine
426 = Cubic inches
HP = High Performance
10 = October (1965)
14 = 14th day
07 = 7th engine assembled that shift
*A 65 or 66 casting date block from a different car COULD be considered technically correct for your 66 car, but only if the block is stamped BH 426, and only if the assembly date is close to your cars Scheduled Production Date (a week or so before, or in some less common cases a few days after the date are the norm) so finding a "correct" engine with the right date and stampings is more difficult than most people think.
If you'd like to know more about your engine you'll need to post more info. The partial VIN stamping will not tell you what exact model it came from (only the body style as Barry pointed out) only where and when it was build, and what model year it may have been installed in. Most blocks cast in mid 1969 ended up in 1970 or 1971 model year cars. Look for more stampings on the oil pan rail extension and the upper pad opposite the distributor, post pics of what you find for more clues as to what you have.
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523039
11/11/09 11:03 AM
11/11/09 11:03 AM
Texas
berrost Offline OP
berrost  Offline OP
Texas
Thanks for all the 66 block info, thee is a very high priced 66 Hemi block on ebay item # 150387073983. If I read the pad as you have decribed I believe it is a BH 426 with a 4-7-27 date.
My cars SPD is 4-29-66 so this block would be correct for my car?
please look at the ebay listing and give me your thoughts.
Re: Where did this 426 Hemi come from? [Re: berrost] #523040
11/11/09 11:22 AM
11/11/09 11:22 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I looked at the block, it's within an acceptable range for your car, in general a bit early but acceptable. The price however, is rediculous IMO, good bare pre 69 blocks don't normally bring over 3-4K
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523041
11/11/09 12:02 PM
11/11/09 12:02 PM
Texas
berrost Offline OP
berrost  Offline OP
Texas
Agree on the price its been on ebay before and never sold - who'd of guessed.
I just finished looking at every section of the 426 for additional numbers but all I have is the stamping and then 2-B's and a WT on the upper pad ny the intake.
thanks
Re: Where did this 426 Hemi come from? [Re: berrost] #523042
11/11/09 12:03 PM
11/11/09 12:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Did you look on the underside surface of the oil pan rail extension (passenger side faces the ground when installed in a car)?
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523043
11/11/09 12:11 PM
11/11/09 12:11 PM
Texas
berrost Offline OP
berrost  Offline OP
Texas
No - engine has been final assembled and as I would really like to know where it came from I also dont want to tear it down.
from the picutre you sent is there usually more than just a date in that location?
Re: Where did this 426 Hemi come from? [Re: berrost] #523044
11/11/09 12:26 PM
11/11/09 12:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That area would be exposed after final assembly. Yes, there can be more info than the example I posted, just showing you where to look. As far as wanting to know where it came from, see my post above. If you send the Vin sequence number to Galen Govier he MIGHT have the matching cars VIN# on record if it still exists, otherwise that's as far as the trail will take you on that block.
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523045
11/11/09 12:48 PM
11/11/09 12:48 PM
Texas
berrost Offline OP
berrost  Offline OP
Texas
nothing on the passenger side but the drivers side I found the following well stamped ID
NM4263570121442
The plot thickens
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523046
11/11/09 12:53 PM
11/11/09 12:53 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
With a 5 19 69 cast date the motor likely came out of a 70 or 71 model car.....the confusing part is the 7 in front of the GXXXXXX. That would have to be a typo.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Where did this 426 Hemi come from? [Re: berrost] #523047
11/11/09 12:55 PM
11/11/09 12:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
NM4263570121442
Per Galens White Book Break Down:
NM = (should be MN?) Marrysville assembly plant
426 = Cubic inches
3570 = 10,000 day assembly date = May 07, 1971
1214 = 1,214th engine assembled
42 = unknown
Can you post a pic?
*BTW, I would assume the "7" in the VIN sequence was a mistake and was probably confused with a "1" when the stamper grabbed it as they look pretty similar at a glance.
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523048
11/11/09 01:06 PM
11/11/09 01:06 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
well there,s not too many 71 hemi cars so it may be a known car...could be worth big $$$ if the car is around dan
Re: Where did this 426 Hemi come from? [Re: ph23vo] #523049
11/11/09 01:08 PM
11/11/09 01:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
IF the car is still around
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523050
11/11/09 01:14 PM
11/11/09 01:14 PM
Texas
berrost Offline OP
berrost  Offline OP
Texas
I am new to this posting stuff - I added the picture above in a previous thread
Re: Where did this 426 Hemi come from? [Re: ScottSmith_Harms] #523051
11/11/09 01:20 PM
11/11/09 01:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
NM4263570121442
426 = Cubic inches
42 = unknown
Can you post a pic?
Wouldn't a May 7, 1971 be for a really, really late 71 built car. Like what is the latest SPD 71 hemi car known?
Just a W.A.G., but could this be a waranty block with a dealer hand stamped vin??
Page 1 of 3 1 2 3
