Recomend a Harmonic Balancer (fluidampr) for strip car.
#522904
11/10/09 10:00 PM
11/10/09 10:00 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
What would you guys recomend,,,brand, part number,,,etc,,,for a harmonic balancer... this is for a wedge motor, strip car,,,, (i think i might have "jacked" up my old one,,,trying to take it off),,,ended up pulling one of the bolts,,and likely stripped it a bit,,,, Still cant get the ^&*()(_*& off...... i have the correct puller device to remove it,,,but the bolts that thread into it came flying off when i started trying to remove the dampr.....arrgghhhhh. Any other "tricks" to getting the old one off ?? Would throwing some HEAT to it,,,hurt anything ?
Re: Recomend a Harmonic Balancer (fluidampr) for strip car.
[Re: 69CHARGERMD]
#522906
11/10/09 11:41 PM
11/10/09 11:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Some guys dont like the fluidampr, I have a couple of them on my SB stuff but I use a ATI damper on my W-9. Use a puller with 3 grade 8 bolts and a impact, if it loads up really hard, stop and smack the end of the big bolt with a BFH for the added shock
[Re: Cab_Burge]
#522909
11/11/09 06:32 AM
11/11/09 06:32 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I had such a problem getting my FDampner on, that I sanded the inside and reduced the interference fit. Should make mine come off with reasonable force...will see soon.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Cab_Burge]
#522912
11/11/09 11:40 AM
11/11/09 11:40 AM
Posts: 1,288 Oregon
sg66mopar
Cab, I used the Permatex anti sieze on mine when I put it on. Maybe there's a better brand out there. Any new dampener should be checked for correct fit (I didn't ) before installing, especially with an aftermarket crank. There's no gaurantee the crank snout OD and hub dampener ID will provide the right amount of press fit. I have the recommended numbers in my shop and I'll look it up today when I have a minute. Also, you can get pullers that use more than 3 bolts. Mine uses 4.
[Re: 69CHARGERMD]
#522913
11/11/09 01:06 PM
11/11/09 01:06 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I have an ATI and a Fluidamper, no problems with either one. I like the looks of the ATI better, lol.
They have to be honed to fit! Putting them on right out of the box will guarantee problems when it comes time to remove it. They should fit no tighter than a factory balancer. CHIP
[Re: 69CHARGERMD]
#522914
11/11/09 01:34 PM
11/11/09 01:34 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I used the ATI 917470E on two engines. It was not necessary to hone, and I have removed one of them without any problem. As said above, I like to use a little anti seise when installing.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#522915
11/11/09 09:00 PM
11/11/09 09:00 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I used the ATI 917470E on two engines.It has aluminum hub. It was not necessary to hone, and I have removed one of them without any problem. As said above, I like to use a little anti seise when installing.
The 917470E has a steel hub, it may need to be honed
[Re: BSB67]
#522916
11/11/09 09:06 PM
11/11/09 09:06 PM
69CHARGERMD
KENTUCKY
What do you guys think of this ? (it is a 917122E),,,would this work ? it says "steel",,,, http://www.jegs.com/webapp/wcs/stores/se...rchTerm=917122EThe previous part number mentioned above is listed as "aluminum",,,,, Does it matter ?
[Re: 69CHARGERMD]
#522917
11/11/09 09:21 PM
11/11/09 09:21 PM
BSB67
Prospect, PA
Does it matter ?
Listed as aluminum shell. It is a steel hub.
The 122 will not line up with the stock pulleys
[Re: BSB67]
#522918
11/11/09 09:32 PM
11/11/09 09:32 PM
69CHARGERMD
KENTUCKY
BSB,,,,thank you.... ps,,how do you know this ? lol,,,, as far as pulleys,,etc, This would be going on a 440 wedge motor with a MSD crank trigger,,,,, Anyway you can tell me what part number would be best for my application,,,, i put a pic of the motor as well if it helps... thank you...
[Re: BSB67]
#522919
11/11/09 09:39 PM
11/11/09 09:39 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Definitely hone the new one and use antiseize, I learned that the hard way a few years ago and destroyed a good balancer. Last year I had one slightly too tight and nothing worked, I borrowed a guy's homemade tool and it came right off, here's a pic....
[Re: Hemi Allstate]
#522923
11/11/09 10:23 PM
11/11/09 10:23 PM
69CHARGERMD
KENTUCKY
This is what is listed in the description...looks like the hub is steel........ Quote:
Aluminum shell/steel hub, 2-ring
It sounds like most people like the ATI over the fluidampr ?????
