Duster Electric Fuel Pump Location #522891
11/10/09 09:12 PM
11/10/09 09:12 PM
dusterjp Offline OP
dusterjp  Offline OP
Need help from all you Duster - Demon guys. I'm looking for pics of were you mounted your electric fuel pumps and pressure regulators. Thanks.
Re: Duster Electric Fuel Pump Location [Re: dusterjp] #522892
11/10/09 10:56 PM
11/10/09 10:56 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
I do not have pic yet but I'm putting mine directly under the rear passenger seat where the back on my frame connectors are welded in,Also I'm piping my filter to the fuel pump with 3/8 pipe nipples and running braided from there to the carb--Steve
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Duster Electric Fuel Pump Location [Re: swifter] #522893
11/11/09 04:33 PM
11/11/09 04:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine is mounted on the inside of the rt rear frame rail, near the spring eye area. With the driveshaft loop, it's protected from being hit if I break a U-joint, it's away from the R/R tire, and it's high enough to never drag the ground. Another consideration is using a floor jack. I like the electric pump to be lower than the fuel tank whenever possible. My car's mini-tubbed, relocated leaf springs ("in the rails") and has never been a street car.
Re: Duster Electric Fuel Pump Location [Re: topside] #522894
11/11/09 08:22 PM
11/11/09 08:22 PM
dusterjp Offline OP
dusterjp  Offline OP
Thanks for the input.
Re: Duster Electric Fuel Pump Location [Re: dusterjp] #522895
02/20/10 08:00 PM
02/20/10 08:00 PM
dusterjp Offline OP
dusterjp  Offline OP
Still hoping for some pics.
