Okay, I bought this truck because noone could get it to start. Had an old 383 in it so I built a new 440 for it. Still wouldn't start (sometimes). Ended up replacing the entire electronic ignition system with an all new Petronix plug-n-play distributor and coil. Locating pin for the cam timing gear on the cam sheared. Replaced with Lunati 3 bolt cam and timing gear drive system for the absolute most in durability. Truck kept overheating so I replaced radiator, water pump, housing, thermostat. Still overheated. messed with timing. Still overheated. FINALLY decided to check valley pan for leakage because cold starts were almost impossible and yall said it sounded like a lean system. Was sucking air from under valley pan so replaced with new one. Still wouldn't start. Thought ignition switch went bad so I put test light on coil neg, and used remote start switch to test and fired right up! Idled for 5 minutes and then just stalled! Won't start! test light on coil neg. flashes when trying to start but no spark! (pulled plug and grounded out on header) SO... has my new Petronix plug-n-play distributor failed on me already???!!!
