Re: 360 Pistons
[Re: duster408]
#522769
11/10/09 07:29 PM
11/10/09 07:29 PM
you mean how many cc's is the dish? there usually 70-80tho down in the bore.
Re: 360 Pistons
[Re: duster408]
#522770
11/10/09 07:41 PM
11/10/09 07:41 PM
RapidRobert
CC's of the dish? If the short block is right in front of you on a stand you could set a thin steel scale across the piston & measure the dia of the dish (A) and slip feeler gauges under it for the depth (B) then 3.1416 X (1/2 of A) squared X B (ie .050") X 16.387064 for the area in CC's or wait for someone to post who has that # handy. Several stock 360's I did the pistons were ~ .100"ish down in the hole (not good).
Re: 360 Pistons
[Re: duster408]
#522772
11/10/09 09:51 PM
11/10/09 09:51 PM
Posts: 29 Minnesota
snojet
Minnesota
yes, I was wanting the cc's in the dish
I have a 2003 360 mag and I just checked the CCs of the dish with fluid and came up with 11 CCs
Re: 360 Pistons
[Re: Intense RT Dan]
#522774
11/10/09 10:27 PM
11/10/09 10:27 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I think the LA piston dish is ~8cc.
mine were .080-.1 in the hole of my old motor...still ran strong with a comp XE262 though
Re: 360 Pistons
[Re: HotRodDave]
#522778
11/11/09 10:21 PM
11/11/09 10:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I didn't measure the piston dish or how far down the pistons were in that motor, on a 97 360 however I find the pistons are .070 down.
Re: 360 Pistons
[Re: HotRodDave]
#522779
11/11/09 11:28 PM
11/11/09 11:28 PM
I just measured the CCs of my 72 360 with the pistons at TDC and grease in the ring grooves to seal them and no decking on the block and measureing the total volume in the cylinder I found 30 CCs in there
30cc? holy man LOL. thought 71/72's were flat tops.
Re: 360 Pistons
#522780
11/12/09 09:09 AM
11/12/09 09:09 AM
patrick
Grand Haven, MI
30cc, but...how far down in the hole are they dave? 4" bore, .1" down in the hole is 20.6cc. you need to subtract that volume, and probably another 1 cc or so for the crevice volume (beween the piston and the wall above the top ring land) from dave's measurement to get the dish volume.
Re: 360 Pistons
[Re: 360view]
#522783
11/13/09 10:40 PM
11/13/09 10:40 PM
HotRodDave
Kalispell Mt.
I have pulled TONS of heads off magnum motors and never seen anything but a graphite type head gasket and NEVER a MLS.
As for the lousy quench thing I think it was because they were too lazy to step up the machining quality where they could consistantly run it real tight.
Re: 360 Pistons
[Re: 360view]
#522786
11/14/09 11:54 AM
11/14/09 11:54 AM
HotRodDave
Kalispell Mt.
I don't know what they are called but they are really flakey stuff like soft flexible graphite stuff with a one layer perforated steel core.
