360 VS 5.9 magnum balancing? #521989
11/09/09 10:27 PM
11/09/09 10:27 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I have weight in the garage to externaly balance a motor but I can't remember if it is for a magnum or LA 360 motor, any one know what the weight of each is? Also any one got the instructions about how far out on the converter it is suposed to be welded? It goes oposite of the rear rod journal correct?
Re: 360 VS 5.9 magnum balancing? [Re: HotRodDave] #521990
11/10/09 01:29 AM
11/10/09 01:29 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
All I can tell ya is the LA 360 takes a much larger weight to balance things out than the Magnum. Rods and pistons were quite a bit heavier.
I would just get the B&M flexplate for the proper application and run with it.
Re: 360 VS 5.9 magnum balancing? [Re: dodgeboy11] #521991
11/10/09 02:01 AM
11/10/09 02:01 AM
Kalispell Mt.
Kalispell Mt.
I am just trying to throw a junk yard jewel type motor together for no $$$ just stuff I have sitting around and was thinking if the weights I have are for a 360 I could weld them to a spare 318magnum flex plate I have here and make my own plate for nothing.
Re: 360 VS 5.9 magnum balancing? [Re: HotRodDave] #521992
11/10/09 08:42 AM
11/10/09 08:42 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Dave, The 2000 & up 360 Magnum flex plate has the weight on them instead of the converter. Just quit being cheap & go to the u pull it yard . There usually just dangling in the breeze
Re: 360 VS 5.9 magnum balancing? [Re: Dos Snails] #521993
11/10/09 12:30 PM
11/10/09 12:30 PM
Kalispell Mt.
Kalispell Mt.
I need to balance one for an LA
Re: 360 VS 5.9 magnum balancing? [Re: HotRodDave] #521994
11/10/09 02:48 PM
11/10/09 02:48 PM
Kalispell Mt.
Kalispell Mt.
OK my weight is for an LA so just need to figure out where exactly it goes
Re: 360 VS 5.9 magnum balancing? [Re: HotRodDave] #521995
11/10/09 04:02 PM
11/10/09 04:02 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I have a diagram in my Mopar engine book but I do not have a scanner...
Re: 360 VS 5.9 magnum balancing? [Re: Dos Snails] #521996
11/11/09 10:55 PM
11/11/09 10:55 PM
Kalispell Mt.
Kalispell Mt.
Does it say how far out to from the center it goes? I think that is the only spec I need to figure it out.
Someone correct me if I am wrong but the weight goes directly oposite of the rear rod throw correct?
