Calling all Thermoquad Experts! again... #521936
11/09/09 09:53 PM
11/09/09 09:53 PM
The Dalles, OR.
Dusted_Ya Offline OP
The Dalles, OR.
Okay been having problems with my 73 440 thermoquad in cold weather not wanting to stay running until warmed up and today after the truck was warmed up and been driven around a little bit acted like it was going to stall so I tapped on the pedal to give it a shot of gojuice and it stalled anyways and then sounded like it ran backwards. Then it wouldn't start. I finally got it to start and run but now if I let off the gas it just stalls. No idle!
I know I have to disassemble and inspect but what should I be looking for that might have went bad?
Retired Mopar fanatic
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521937
11/09/09 09:59 PM
11/09/09 09:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
First question, are 100% certain it's the carb?
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521938
11/09/09 10:21 PM
11/09/09 10:21 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Demon sizzler will build you a great carb, but I would read and do this first.
http://www.thermoquads.com/page204.html
Re: Calling all Thermoquad Experts! again... [Re: ScottSmith_Harms] #521939
11/09/09 10:24 PM
11/09/09 10:24 PM
The Dalles, OR.
The Dalles, OR.
Well pretty sure. Everythings new I suppose it could be the new petronix plug-n-play distributor but I highly doubt it. I checked to see if each cyl was recieving spark when it wouldn't start and they all were. so it's got to be fuel related...
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521940
11/09/09 10:31 PM
11/09/09 10:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If you are certain it's fuel related dont be so quick to dig into the carb itself. The first thing I'd do is check for a clogged fuel filter, trace everything up to the carb intself first, if it's good then search for a vacuum leak, (a dry rotted rubber vacuum hose is a common problem and can cause intermitant issues like that) have you had a vacuum gauge on it while it's running?
You said it has issues when both hot & cold, is your choke opperating properly? Maybe hanging up or sticking?
Re: Calling all Thermoquad Experts! again... [Re: ScottSmith_Harms] #521941
11/09/09 10:45 PM
11/09/09 10:45 PM
The Dalles, OR.
The Dalles, OR.
First thing I checked was for a vacuum leak. New hoses but I'll recheck in the morn. Never checked the fuel filter as it's fairly new (about 1500 miles on it). It's getting fuel via the accelerator pump so I'm assuming that it's not running dry. not vacuum gauged it. Just acting like it was running out of fuel at idle. Just noticed lately when it was cold started I had to pump it about 3-5 times to get it to fire up then it would start and run good for about 5-10 seconds then stall at any RPM until it got hot. Then it was usualy fine. Now all of a sudden when it's hot it will start and run as long as the RPM's are up but once you let off the gas it stalls. I think my choke (mechanical heat type)is not working properly which would explain the cold start problems but not the hot idle problem?
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521942
11/09/09 11:02 PM
11/09/09 11:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hmmm, well be sure the choke is functioning properly then trying a vacuum gauge would be the next move, see if it holds steady or fluxuates. Try spraying some starting fluid around the base of the carb and the intake and see if it picks up any rpms, sometimes leaks come and go with hot/cold situations.
Re: Calling all Thermoquad Experts! again... [Re: ScottSmith_Harms] #521943
11/09/09 11:38 PM
11/09/09 11:38 PM
The Dalles, OR.
The Dalles, OR.
I'll check that out in the morning!
Thanks!
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521944
11/09/09 11:48 PM
11/09/09 11:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem, if you ever get up to Spokane I'll be happy to have a look at it for you "on the house".
Good luck!
Re: Calling all Thermoquad Experts! again... [Re: ScottSmith_Harms] #521945
11/10/09 12:45 AM
11/10/09 12:45 AM
The Dalles, OR.
The Dalles, OR.
Bought my 67 D100 stepside there about a month ago.
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521946
11/10/09 12:50 AM
11/10/09 12:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
From Ralph?
Re: Calling all Thermoquad Experts! again... [Re: ScottSmith_Harms] #521947
11/10/09 01:05 AM
11/10/09 01:05 AM
The Dalles, OR.
The Dalles, OR.
don't remember his name. White with blue racing stripes
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521948
11/10/09 01:09 AM
11/10/09 01:09 AM
The Dalles, OR.
The Dalles, OR.
I emailed you some pics.
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521949
11/10/09 12:02 PM
11/10/09 12:02 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
if you do rebuild it, remember to check the jet wells for fuel leakage. This would cause a over rich condition.
Re: Calling all Thermoquad Experts! again... [Re: ademon] #521950
11/10/09 12:06 PM
11/10/09 12:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I saw that truck but I don't think Ralph had it (hes a local friend of mine who buys about every old Dodge truck he sees).
*I gave your carb problem some further thought. Try unhooking the fuel line at the inlet and turn the engine over until you are sure the carb is out of fuel, this will drop the floats down lifting the needle all the way from the seat, then hook it back up and start it up. Sometimes if there is some crud clogging the seat the incomming fuel will wash it out when it's opened up like that. Also, once you eliminate all external possibilities, you would want to be sure you don't have a leaking/sunk float. The internal "O" rings ademon mentioned can certainly cause issues but it's not that common for them to just suddenly fail, it's usually something that surfaces immediately after a rebuild due to an impropper installation.
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521951
11/10/09 01:33 PM
11/10/09 01:33 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Sounds like a lean condition. Generally speaking, a lean T.Q. will have a poor or no idle circuit until the engine and intake are warm enough for the fuel and air mix to atomize. At this point, the engine will gain most of the idle circuit but will likely still be lacking, David.
ThermoQuads:stock, street/strip and race; 800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's. New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating. Carbs bought and sold. Consulting on pre-purchases so you get the right carb the first time.
Re: Calling all Thermoquad Experts! again... [Re: Dusted_Ya] #521952
11/10/09 01:44 PM
11/10/09 01:44 PM
Washington, PA.
69charger383 Offline
Washington, PA.
Fuel pump maybe? How much pressure do you have at idle & at higher rpm?
Re: Calling all Thermoquad Experts! again... [Re: DEMONSIZZLER] #521953
11/10/09 01:47 PM
11/10/09 01:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I was thinking along those lines as well David, but when it does it after warming up I started thinking otherwise (like it may not be the carb at all).
Either way, long distance diagnoses of a carb issue isn't much more than a guessing game/process of elimination IMO, which is why I usually stay off these types of threads. Hopefully he'll get to the bottom of it and we'll all know for sure.
Re: Calling all Thermoquad Experts! again... [Re: ScottSmith_Harms] #521954
11/10/09 02:03 PM
11/10/09 02:03 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Another vote here for a LEAN condition...... and could the OP have NO CHOKE and a blocked intake heat cross-over also ?
That makes cold-starts even worse.
Re: Calling all Thermoquad Experts! again... [Re: DEMONSIZZLER] #521955
11/10/09 02:56 PM
11/10/09 02:56 PM
The Dalles, OR.
The Dalles, OR.
I've been suspecting my valley pan isn't sealing right since I reused the old one when I did a cam change. Think I'll pull it off and install a new one just to be sure.
