first i just want to say whats up since its been awhile since ive been on here.
awhile back i installed a TCI full manual raverse valve body in my 727. i bought this off ebay and it did not come with a kit.(i was unaware of the this) so i just put the valve body in. my mistake i understand now it wont happen again. when goin down the road it started to pour trans fluid out the front like it was the seal. so i pulled the valve body and put the old back in. and changed the front seal. put the trans back in and it does the same thing. pours trans fluid out the front. its not the seal because its new. and i changed it even thought the old one was still good. i think its coming from the vent im not sure. can someone give me some sort of explanation as to what happened. maybe you experienced this problem.
