Re: Valve Cover Bolts with Alum heads?
[Re: 85_Ram_4speed]
#520336
11/09/09 10:43 AM
11/09/09 10:43 AM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
Stainless works fine. But if you are going to use a regular bolt, I wouldn't use anti-seize. Good trick--get some liquid antacid from the pharmacy like Maalox or something. Put a little Maalox on the threads before you install the bolt. It keeps the two dissimilar metals from corroding together and it dries to a powder, acting as a light duty threadlocker. I've used that trick for years in all kinds of applications and it works great!
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: JoesMopar]
#520338
11/09/09 02:41 PM
11/09/09 02:41 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Which Alum heads? Eddy's are helicoiled so your not actually putting 2 disimilar metls together.
I'm sure other heads have helicoils as well.
