Plumbing fuel pump bypass #520104
11/08/09 11:09 PM
11/08/09 11:09 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
Is it okay to run the fuel return to the top of the fuel tank or should a line be run to the bottom? I'm not sure why but it doesn't feel right to spray the fuel into the tank like you would get excess vapor or something.
Re: Plumbing fuel pump bypass [Re: mt162] #520105
11/08/09 11:18 PM
11/08/09 11:18 PM
sg66mopar Offline
sg66mopar  Offline
Jaz Pro Stock fuel cells come with fittings in the top for return line and vent hose. That's what I run and it works great.
Re: Plumbing fuel pump bypass [Re: mt162] #520106
11/08/09 11:27 PM
11/08/09 11:27 PM
I like to feed it into the bottom to avoid making vapors and static electricity
